|   | No Sound From Gas Tank. Vehicle Not Working. |
| 11.06.2022 18:21 | # 1 |
|  SerkanMutlu | |
| 12.06.2022 13:14 | # 2 |
|  SerkanMutlu | |
I need help from the masters.
| 12.06.2022 13:15 | # 3 |
|  x571 | |
You can get the best results by measuring the fuses. other than that, if it's working for now, don't install it at all. If it does it again, replace the relevant fuse.
| 12.06.2022 21:33 | # 4 |
|  SerkanMutlu | |
The vehicle gave the same fault again today, I removed the gasoline arc seat and wanted to look at the fuel pump, there was a blue dry under the cover of the tank. It goes to the tube tank, what is the use of this thing… also the place where the tube tank is filled with water, I don't know where it got in because of the rain.. | |
| 13.06.2022 16:11 | # 5 |
|  KILIC | |
This blue box is probably a time relay. When the car switches to LPG, it automatically stops the fuel pump. There may be a problem with the role.
| 15.06.2022 09:07 | # 6 |
|  sonerkyl | |
The blue part timing relay right there automatically turns it off so that the fuel pump doesn't break down when the vehicle passes LPG.
