no problem
08.05.2020 18:51 # 1
pekmez006
it's done pekmez006 2015-07-28 18:05:44
08.05.2020 18:51 # 2
CrimsonChild
Does this problem make the vehicle brand model, whether the vehicle is LPG or petrol or diesel, when LPG gas adjustment was last done, when the vehicle was first started, or while waiting in traffic? If you can answer them, you will get clearer answers for help.
08.05.2020 18:51 # 3
pekmez006
I fitted the LPG to the 2003 model 1.6 gasoline vehicle. I got the lovato and OBD kit. The fault lamp lighting from LPG is a bit more than 0%. The lpg setting has been done, the throat butterfly has been cleared and it is doing it in the first run.
08.05.2020 18:51 # 4
berk2309
After cleaning the throat butterfly, I was calibrated after cleaning
08.05.2020 18:51 # 5
CrimsonChild
Have a look at the valve settings, the layout must be very sensitive in Lpg. Even if one of the coil ends has cracks or a damage, it also creates a problem.
08.05.2020 18:51 # 6
pekmez006
Calibration was also done
08.05.2020 18:51 # 7
Ahmet_ach
do it from the oxygen sensor, I think, reset the brain, try again, remove the battery pole press, press the brake a few times to remove all the electricity in the vehicle.
08.05.2020 18:51 # 8
pusutr
How are the spark plugs?
08.05.2020 18:51 # 9
pekmez006
All is new 10 thousand and let me see last week good idling valve was not checked
