No power is supplied to the fan of 2 steps. |
| 09.03.2021 10:20 | # 1 |
When the headlights and fog are on in my car, the temperature is 10 degrees above. While I was checking this, I realized that the 2nd stage of the fan was not working. I temporarily solved the fan problem by pulling + from the ignition fuse, but could not fix the temperature rise with the headlight and fog on. I think there is a problem in the chassis but I did not know where to look. In both matters, can friends who have come to you before can help? |
| 10.03.2021 17:37 | # 2 |
Probably the electrician pulled electricity from the wrong place for fog or something. You did not specify what your vehicle is, but if it is 206, there are fan roles behind the peugeot emblem. Check them out.
| 11.03.2021 08:58 | # 3 |
2-stage electricity problem has been solved. Electricity has been taken in different places than the fan fuse, the room has burned the fuse. When 2 fuses were changed, the system returned to normal, we stopped the vehicle after we took the vehicle and went 8 km.If the battery did not get charged, we went again, the charger was dismantled, the alternator was dismantled, and the problem was solved when it was recovered properly. Why could this dynamo be out of power?
