No more filling place complex in the new LPG regulation |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » All Questions About Your Vehicle | |
| 08.05.2020 20:21 | # 2 |
sonerkyl |
Thanks for the information, teacher, but technicians at tuvturk stations each of them is attached to the head unfortunately.
| 08.05.2020 20:21 | # 3 |
[QUOTE = sonerkyl] Thanks for the information, teacher, but technicians at tuvturk stations are all stuck in different heads. [/ QUOTE] If the forum members have problems after having such an article from TÜVTURK, let's complain to the center. Let the law be whatever the rule is. if it was already a bad practice, they would not allow those tools that way. |
| 08.05.2020 20:21 | # 4 |
Ahmet_ach |
Another way to cut tribute, the friends who will go to the inspection must have the lpg filling place in the bumper, even if it is done before the inspection, it is better to go to the buffer, otherwise, there will be a renovation in the meantime, the vehicles with lpg want before the inspection; Insulation between lpg tank and sase, 3rd generation and gas filling place for lpg tanks are required to be buffered |
| 08.05.2020 20:21 | # 5 |
[QUOTE = Ahmet_ach] Another way to cut tribute, the friends who will go to the examination should have the lpg filling place in the bumper, even if it is done before the examination, otherwise it is going to the bumper, so that the renovation will be in the meantime; Insulation between lpg tank and sase, 3rd generation and gas filling place for lpg tanks are required to be buffered [/ QUOTE] I do not know very deeply, but my vehicle was first fitted with LPG by 2 owners before the inspection period. The lpg input is not in the buffer. If it was against the law, it should not have passed 2 examinations. |
| 08.05.2020 20:21 | # 6 |
Friends stations may differ. the law has come into force and this practice will be activated at all stations. The LPG of the persons who came while the LPG was mounted had expired. This is an indication that the LPG is 10 years old. Why did the old assembly ask for the gas filling nozzle to be mounted on the bumper? that is, there are brief differences between the stations. sealing 35 TL saddle, if you install the gas filling nozzle in the bumper without going to the inspection station, the sealing will not be required, but if you return from the heavy defect, the modification report will be prepared and the sealing condition will be. assembly + sealing
| 08.05.2020 20:21 | # 7 |
maximusti |
[QUOTE = Peugeot35] Friends stations may differ. the law has come into force and this practice will be activated at all stations. The LPG of the persons who came while the LPG was mounted had expired. This is an indication that the LPG is 10 years old. Why did the old assembly ask for the gas filling nozzle to be mounted on the bumper? that is, there are brief differences between the stations. sealing 35 TL saddle, if you install the gas filling nozzle in the bumper without going to the inspection station, the sealing will not be required, but if you return from the heavy defect, the modification report will be prepared and the sealing condition will be. assembly + sealing [/ QUOTE] exactly, If they want the mold to put the filling nozzle in the buffer, they definitely want a leak proof report. it makes more effort, You will either disassemble the LPG and enter it for inspection, or you will do what it says.
