No matter what i do
08.05.2020 20:37 # 1
CmGns
S.â friends 99 model 306 griffe I have a car recently caused an error caused by the gas pump, the car is not working du solved the problem but the back is not interrupted until it finds the fault, now the problem is running when the car is cold, it does not work when it gets hot but it does not take the engine but it can not take the engine for a long time. . The spark plugs connected to it may be blocked by the grang heating sensor gasoline pump or even a master exhaust manifold. My problem is when the vehicle is running when it's cold, it doesn't get started the next time if I pass it, but it doesn't always do this. There is nothing in the coils. I looked at the electrical wiring and the brain is left. What do I think should I do? the car is my car gasoline 1.6 I would be glad if you help, so the car is burning more than enough now 60 kurus fuel cmgns 2017-11-02 21:19:43
08.05.2020 20:37 # 2
peugeotefe
As far as I understand, when the vehicle is hot, it starts, but the vehicle has difficulty in starting. When you start the car when it is hot, when you start it, you need to look at it when petrol and ignition are coming.
08.05.2020 20:37 # 3
CmGns
He said he did not change until the Bosphorus, but the room you will understand until the other exit does not take any money when the car is cold just for the sake of making money, but if you go even 1 km, the starter stops, it does not get pumped, black smoke and idling are found until the engine finds itself at 25 thousand revolutions. it is going on then it is around 10 thousand, the coil said it was solid, but one eye was black, spark plugs were burned before it changed, it said its job did not need to change and I took the gas pump out, I wonder if the engine does not pump the gas fully, so I would not work, if I did not know if I change it, I would change it. The reason was that when the engine malfunction light first came on, there was an exhaust oxygen sensor and engine heating element malfunction, it was solved on the computer.
08.05.2020 20:37 # 4
peugeotefe
306 1.6 engines, the exhaust manifold is inside, your car is likely to be the same way as you have told you that fuel is coming to the car but it can't burn the fuel, so it doesn't throw out the fuel it burns. not the case
08.05.2020 20:37 # 5
CmGns
I will change the manifold in the morning, then it will come out as you wish, I hope I will return to you on the subject, thank you
08.05.2020 20:37 # 6
x571
[QUOTE = CmGns] I will change the manifold in the morning then it will come out as you wish I hope I will get back to you on the subject, thank you [/ QUOTE]
positive and negative, write here also be useful.
08.05.2020 20:37 # 7
peugeotefe
You're welcome
