no matter what i did
08.05.2020 18:50 # 1
ergin1983
Hello friends
I use the peugeot 206 1.4 HDI 2004 model vehicle, I can even say that I am trying to use it. my car does not work sometimes. It works after a while when I pump the handle grip pump. Based on this, I changed the handle grip system completely and gave 400 TL. At the same time, I replaced the diesel filter with the original one, and when I came home in the evening, I tried it again. I'm about to freak out. I know that all the lights must go out when we turn the ignition when starting the diesel vehicle. Well, when we turn the ignition, 00000 light flashes in the area written by km, should we wait for it to return to normal? please help or I'll burn the car
08.05.2020 18:50 # 2
zr`lmn
I do not know the diesel vehicle at all, but the 00000 ueri oil pressure indicator which is written in km. I know that those circles have a sign similar to the arrow mark and show the level of oil. Get well soon
08.05.2020 18:50 # 3
jack67
Look at the diesel hose, bubbles appear if it makes air. It works by pumping but does not work directly. If you start with a new one, there is no problem.
08.05.2020 18:50 # 4
ergin1983
If the hose that you call diesel hose is connected to, I replaced it completely
08.05.2020 18:50 # 5
jack67
Maybe there is a leak ahead of the line, have a check. Or your diesel pump is likely to be in trouble. If the pump cannot grow diesel, it does.
08.05.2020 18:50 # 6
ergin1983
Don't say "diesel pump" for God's sake, I have no power anymore: ((((((
08.05.2020 18:50 # 7
oktan24
The same problem was also present in me. All hoses, including the handle grip system, have changed. The same problem has continued.
08.05.2020 18:50 # 8
HardPilot
If it is used for a long time or has difficulty while the diesel filter is faulty, it damages the injectors. But before this possibility, if you hit the bottom of the vehicle somewhere, there is a layer of approximately 10 * 20 cm under the vehicle. Check the hoses attached to it throughout the vehicle. Are there crushes? it is probably not able to draw the required diesel from the tank. This makes it airy and breaks the filter again.
08.05.2020 18:50 # 9
ndm01
Hi
I had the same problem last year, I changed the diesel filter of my car and when the winter came, my car was running when the weather got cold but it stopped and it did not work without pumping to work again. I did this every day for a winter day. It is useful to check your diesel filter.
08.05.2020 18:50 # 10
Dewil1606
The same problem happened with me. If you repeat the diesel filter and do not correct it, it does not make air in the handle part of the handle, check it, die, if there are small bubbles, it is making certain air.
