No malfunction, but traction is low
08.05.2020 21:28 # 1
darkiron
Hello everyone. I came back about 1 year later :) Peugeot 307 2006 1.6HDI We have a 110Hp vehicle. We have done 210,000 maintenance to the vehicle in the past weeks. All fluids have changed, except transmission oil and brake fluid. In addition, the Timing apricot and circulation pump changed to the front brake disc and pad, and only the pad in the rear brake. All the parts have been replaced with their originals. Now, as you know, there is an event called turbo overboost in this vehicle. who knows already. Traction of the vehicle was low. We went to the master and the master said that it might be from egr electrovan, he removed the egr and cleaned it (it wasn't dirty anyway). previously it was malfunctioning from the solenoid valve, but traction is still low. It feels like the turbo doesn't pressurize officially. what could be the reason for this By the way, it may also be for winter reasons, while the vehicle normally burns 5.8-5.9, it is now traveling in 6.8s. vehicle revolves, not just power. The malfunction does not turn on the light either, but one has to look at a computer. I'm waiting for your help :) the darkiron 2020-02-18 19:09:46
08.05.2020 21:28 # 2
mehmetgldgn
Hi;
I recommend you to connect your vehicle to the device with peugeot planet 2000 software. Software like Delphi cannot see most malfunctions in the vehicle, and since these malfunctions contain codes specific to the manufacturer's program, the original software provided by the manufacturer, peugeot planet 2000 software, detects these malfunctions. In this way, by eliminating the logic of defect parts, failure detection can be done with more economical methods. (Remember, not every malfunction can illuminate the malfunction lamp in the vehicle.)
08.05.2020 21:28 # 3
darkiron
I don't know if there's a place I can find near me. I live around an eagle. I wonder where can I find it?
08.05.2020 21:28 # 4
mehmetgldgn
You can find the pp2000 device that makes auto brain repair, that is, electronics, and if you ask in the industry, you can direct it. (If your vehicle has a malfunction, take note or photograph the malfunction code and description to show it to your master) mehmetgldgn 2020-02-18 22:12:58
08.05.2020 21:28 # 5
darkiron
Thank you for the information. I will search.
08.05.2020 21:28 # 6
darkiron
[QUOTE = mehmetgldgn] Auto brain repairers, that is, electronicists can find the pp2000 device, if you ask in the industry, you can direct it. (if there is a fault in your vehicle, take note of the fault code and description or photograph it to show it to your master) [/ QUOTE]
By the way, I was looking at the faults with the diagbox software again, I guess it does not show details.
08.05.2020 21:28 # 7
peugeotefe
Hello, when did your breakdown start and when was the low traction in the vehicle?
08.05.2020 21:28 # 8
darkiron
[QUOTE = peugeotefe] Hello, when did your malfunction start and when has the vehicle traction low [/ QUOTE]
Hello. Before maintenance, sometimes the traction was in place, sometimes it was going but the traction is low since egr cleaning. egr cleared errors from diagbox deleted but nothing changed. As time will be up to 1 month.
the darkiron 2020-02-18 23:13:13
08.05.2020 21:28 # 9
also have the turbocharger hoses checked, sometimes cracks etc. or it can cause this in the wrong connection. as if there is a vacuum problem
08.05.2020 21:28 # 10
darkiron
[QUOTE = sonerkyl] Also have the turbocharger nozzle checked, sometimes cracked etc. or it can cause this in the wrong connection. as if there is a vacuum problem
Recently, there was a noise in the vehicle's engine that increased as the speed on the air filter side increased but I could not find it exactly. It wasn't a blowing sound, I'm sure of it. I'll take it to the master when it's time, but I'm still waiting for guesses ...
08.05.2020 21:28 # 11
darkiron
Hello. Little, I want to make an update that gives me some happiness. The vehicle's traction is now in place. There was no problem going just like before. The car officially gives power or not depending on your enjoyment: D let's see when the traction will drop again (hopefully not).
08.05.2020 21:28 # 12
In addition, clean the air meter deep. How is the condition of the printing pad, by the way. Also, be careful about whether this problem is giving in hot and dry weather or do you encounter more in rainy weather.
08.05.2020 21:28 # 13
darkiron
Printing pad is just new. The fall in traction happens in all weather conditions, I did not pay full attention, but it was always low in dry weather, it was traction in rainy weather yesterday. If I find that the traction is low in dry weather again, I will write directly. the darkiron 2020-02-21 12:11:01
08.05.2020 21:28 # 14
347234
Malfunction electro valve you have cleaned a valve that controls the turbo. But it would be nice if you change it. It has a vacuum providing engine. It does not work very well when its life is over. If you cleaned the sensor in the air inlet of the filter, there is also a map sensor. due to the age of the fragment does not work as before can make traction low
I hope it will be useful
If it does, return and let us benefit
Good luck with
08.05.2020 21:28 # 15
darkiron
Hello everyone, the traction was good 2 days ago, but it is still gone today. The vehicle says I will not go, Naz started to do it officially. Since there is no time I did not clean any sensors. Can I do this cleaning myself?
08.05.2020 21:28 # 16
ismailkaya
there is an air leak or turbo or catalyst plug
08.05.2020 21:28 # 17
darkiron
sometimes there is a louder sound coming from the rear of the engine (air filter side) as the car rolls over. I guess what is likely to be an air leak
08.05.2020 21:28 # 18
ismailkaya
check for any cracks in the air hoses at least check at high speed
08.05.2020 21:28 # 19
darkiron
I control the sound I said at high speeds in my spare time. If there is a problem with the pipes, how long are the new pipes original?
08.05.2020 21:28 # 20
https://www.otoyedekmarket.com/kategori/307-1-6-dizel-3?tp=2
Page : / 2
