no horn
08.05.2020 15:23 # 1
cash1912
Sorry, my friends, my car does not stop at all. The horn sometimes does not work, especially there is a point to stop there.
08.05.2020 15:23 # 2
metin
contactlessness oxidation or something. most of them are 307 but I don't know if there are 206's. you can solve the problem with a nice cleaning. They announced as an illustrator in the forum, it is really helpful.
08.05.2020 15:23 # 3
cash1912
Where exactly did they give
08.05.2020 15:23 # 4
ibanez_022
Friends do not sound the horn on me too, is the airbag or something deniyo? craftsmen help
08.05.2020 15:23 # 5
ismailkaya
What does it have to do with Eğirbek? I think the master says, Eğirbek. I think the cable is missing or if you pressed too much, the fuse has blown or the engine is in the horn connection socket there.
08.05.2020 15:23 # 6
muhoist
I also had the problem of the horn not working, I removed the head of the battery first because we have to remove the hub of the steering wheel so that the airbags do not get electricity. Turn the steering wheel 90 degrees and let it look, you will see a hole on both sides. Press a thin screwdriver there. There are clips of the steering wheel hub. When they are released, if the hub is opened, you will see the cables on the right and left.
08.05.2020 15:23 # 7
ibanez_022
I made it today, only the socket on the motor side has been removed, plugged and worked ..
