No gas cut at the bipper shift |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » Bipper | |
| 08.05.2020 14:51 | # 1 |
I just joined you. I was not aware of the existence of such a forum. I noticed when I was researching the failure of my vehicle. I got very useful information. I couldn't find information about my problem. I'll be happy if you can help me. I have a 2009 model Bipper. I bought my car zero. After 15-20 km after exhaust inspection with 12000 maintenance, the gas is cut slowly in gear changes. (Tachometer normal) My vehicle makes a forward attack if I change speed. No problem if I change it slowly. I have had all the maintenance done in the service so far, as it is guaranteed. Although I take it to the service every month, they said there is no such problem in your vehicle. I suspect the vehicle has a problem with its brain. Thanks for your help in advance.
| 08.05.2020 14:51 | # 2 |
I have the same problem, could you find a solution? |
