no gas and working like diesel when cold
08.05.2020 15:05 # 1
duse
friends, when my 2002 model 307 xr 1.6 car usually shifts to 2nd gear and loaded on the throttle, the car cannot accumulate and recover, and the engine malfunction lamp is on, then when I pull off the ignition and the ignition is turned off, the malfunction lamp turns off and goes back to normal. it sounds like blowing, it runs noisy, it returns to normal but there is still sound.
08.05.2020 15:05 # 2
peugeotefe
We will help you better if you introduce yourself to our members' section
08.05.2020 15:05 # 3
duse
Is there anyone to help?
08.05.2020 15:05 # 4
[QUOTE = duse] friends, my 2002 model 307 xr 1.6 is usually in 2nd gear and when it is loaded into the gas, the car cannot stack and recover, and the engine fault lamp turns on, then pulls aside and turns off the ignition, the fault lamp goes out and returns to normal. sometimes it stops and sounds like blowing, it runs noisy. It turns back to normal when it starts but there is still sound. [/ QUOTE]
One of the intercooler hoses entering the engine is probably split Göz Kırpma
