No gas
08.05.2020 19:36 # 1
ozgorh
Hello friends, there is no problem when going on LPG. When I go on gasoline, I do not eat gas when I shift into 2nd gear.
08.05.2020 19:36 # 2
ozgorh
Does anyone have an experience or idea?
08.05.2020 19:36 # 3
ssakyel
Hello, first of all,
The pressure can control the lining of the lining pad, if it is near to the end, it can cause this problem. Do you change gears when you reach enough speeds?
08.05.2020 19:36 # 4
ssakyel
Hello there,
Dude, the pressure pad can be yours again. If you want a check.
08.05.2020 19:36 # 5
Dzking
It feels like a gas pump or something related to gasoline. So it looks as if there is a gap in the gas after the first action. I heard a lot of comments.
08.05.2020 19:36 # 6
dsinan26
Renew your engine oil. I recommend SHELL HELIX. The problem will be fixed.
08.05.2020 19:36 # 7
Dzking
There are 10/40 motuls on it. What does it have to do with oil? I would appreciate if you give information. Good forms
