No battery start
08.05.2020 21:02 # 1
Karacocuk24
Friends, the starter does not press fully, so when I will freeze, I say cit cit bedding, it stops, I reinforced it from another vehicle. I tried to take a spare starter for 15 seconds. When the car was closed, the green light of the battery seemed to burn, after the start of the mars it was like a black, then it became green then the battery was bosh brand and from where If you look at the vehicle, I have been in the previous owner for 3 years and I have not done any maintenance for the last 2 years.
Note: I entered a grocery store 2 weeks ago, when the quadruples were open, we made cit cit before mars fully frozen in the same way.
Karacocuk24 2018-10-03 21:45:54
08.05.2020 21:02 # 2
ykuyucu
battery is dead take a new one
08.05.2020 21:02 # 3
Do not look like it is green, the battery is dead now bro. Time to change
08.05.2020 21:02 # 4
Karacocuk24
Thank you friends, 250 TL for your answers
08.05.2020 21:02 # 5
ismailkaya
The battery won't die, so your starter dinomon might have scrapped dee
08.05.2020 21:02 # 6
Karacocuk24
[QUOTE = ismailkaya] The battery will not die, your starter dinomon may have scrapped dee accordingly [/ QUOTE]
How the battery does not last, which sources do you base it on?
08.05.2020 21:02 # 7
HasGur
[QUOTE = Karacocuk24] [QUOTE = ismailkaya] The battery will not die, your starter dinomon may have scrapped dee accordingly [/ QUOTE]
The acidic water in the spirit of the battery ... When it drains the water, the soul leaves the body and the battery dies :)
08.05.2020 21:02 # 8
Karacocuk24
[QUOTE = HasGur] [QUOTE = Karacocuk24] [QUOTE = ismailkaya] The battery will not die, your starter dinomon may have scrapped dee accordingly [/ QUOTE]
There was a problem that the pole did not oxidize for 3 years.
08.05.2020 21:02 # 9
ismailkaya
Ok guys, I admit that the battery is dead) I say a different subject that I was talking about may be caused by the starter dynamo.
08.05.2020 21:02 # 10
HasGur
We made reinforcements and worked immediately
[QUOTE = ismailkaya] I am saying that a different topic I mentioned might have originated from the starter dynamo [/ QUOTE]
If there is a problem with the starter motor, the reinforcement will not work.
