NO BASS SOUND
08.05.2020 17:16 # 1
mayday06
hello friends. original edison mono bass amplifier pioneer 1400 wat double coil bass super bounce car not focused, for x 1600 wat 150 rms speakers, 4 channel amps are connected. front and doors are directly connected to tape. When I come up, when I raise the sound, the sound decreases, it becomes incomprehensible music.
08.05.2020 17:16 # 2
outlaw
Subbass & nbsp; like Sony pioneer You can get more efficiency from the output tapes.
Try adjusting the bass tizz on the tape.
08.05.2020 17:16 # 3
mayday06
I did, but it doesn't help much.
08.05.2020 17:16 # 4
Burak
I think that the person who connects the installation will be able to adjust the view again or something like removing an amp.
08.05.2020 17:16 # 5
mayday06
they have double amps ovals are not good they said & nbsp;
08.05.2020 17:16 # 6
mayday06
I bought the ovals from the net, the tape recorder said, let's try it with other brands. You will see the difference. edited>
08.05.2020 17:16 # 7
istanbullu-3885
Try to increase the wattage of the sound amplifier.
08.05.2020 17:16 # 8
cerci07
change tape
08.05.2020 17:16 # 9
The ovals are already bass-intensive.
As far as I understand, the components in the doors are not connected to the amplifier. More precisely, the component is not. Coaxial. If you want to get sound, the sound system on the vehicle should be as follows.
Remove the ovals. At least 70 rms to the front and 50 rms to the back of the component. Let the tape have an amp output. You can put it on the mono 2 amps.
Also, wiring is important, you need to pull 2 ga cables from the battery to the amps.
08.05.2020 17:16 # 10
As far as I understood, you couldn't get the tis because you installed the installation in the back, the ovals are in the back.
