Nitrogen gas is injected into the vehicle tires ???
08.05.2020 18:49 # 1
okaNStarss
Mrb friends, a friend of mine has 4 tires that pressed nitrogen on the tires of the opel, like 20 TL. After doing this, he tells that the car's voice has changed and that he is relieved. In order to make their sibop aging, they also made sure that they would get cold and cold in summer and winter. Do you have such a situation and friends who have experience can share information.
08.05.2020 18:49 # 2
peugeotefe
It is true that the comfort changes in the vehicle, and this depends on the tire condition.
08.05.2020 18:49 # 3
oguzhan53
The only benefit I have seen is constant at 32 psi in summer and winter for 1 year. Air supplements were required once a month before.
08.05.2020 18:49 # 4
SEZGIN72
Hi;
I also pressed nitrogen when replacing the rims at the beginning of last year. I did not give in money :) I did not see a difference in comfort or sound. But it is a fact that almost a year tire pressures never dropped 32 PSI remained constant. I advise...
Of course, before doing this, it is also useful to remove rust from the rim of the tire, if the rims are old. The rust and deposit residues here cause air leakage.
Good luck with...
08.05.2020 18:49 # 5
pusutr
forever nitrogen.
08.05.2020 18:49 # 6
Efe-Pojo
This car is my 3rd car, I never pressed nitrogen on this and any of the previous ones, and I never had any tires.
08.05.2020 18:49 # 7
okaNStarss
Thank you for the CVs, friends, when I change the tires, I will try to press nitrogen to see what happens :)
