Newly bought 206 also annoying steering problem
08.05.2020 20:18 # 1
aslan
Hello friends, I have a problem with the 206 1.4 xr 99 model in my new vehicle.
The steering is very hard when it first starts in the morning and I do a few right-left clicks and it returns to normal, so when it pushes a little hard, it turns to the noon. While the vehicle is in motion, there is no problem in small maneuvers, but when it is done by a hub or full maneuver, it repeats again. I want to benefit from the experience of friends with knowledge, thank you in advance
08.05.2020 20:18 # 2
Just like the problem from the coach steering pump, first check the oil level.
08.05.2020 20:18 # 3
aslan
I came to my mind when you said the oil was full of oil, but the oil was very dirty, I took a new old oil in a gray color with a syringe.
08.05.2020 20:18 # 4
Since it has lost its feature over time, you have to empty all of them with a syringe from the difficult teacher.
08.05.2020 20:18 # 5
aslan
I showed my problem to 2 masters, one said to the steering box, we repair it, said 450 TL, said in the handle of the steering pump. I was not satisfied, I went to another master, the room made me angry, I said that I said either the steering box or the steering pump. Angry Then, if the brother broke down and repaired, both of them changed with 650 new ones, both said 1300, when I heard the prices, I said I was angry, but I think I didn't know what to do in my opinion?
08.05.2020 20:18 # 6
ggitaristt
Does the electric hydraulic pump stop sounding when the steering wheel stops?
08.05.2020 20:18 # 7
sdttn
Not electric pump. The master is probably correct, show it elsewhere.
Fat (ATF) turns brown when it is old, it may be a sign that there are metal legs in gray.
sdttn 2017-04-24 17:44:04
08.05.2020 20:18 # 8
aykutbayram1996
Does it happen when the vehicle is cold, or does it return to normal when it gets hot? As the friends say, either from the pump or the steering wheel.
08.05.2020 20:18 # 9
ggitaristt
How is the pump not electric? When my pump broke down, the master said we would make 206 pumps!
08.05.2020 20:18 # 10
sdttn
[QUOTE = ggitaristt] How is the pump not electric? When my pump broke down, the master said we would make 206 pumps!
He wanted to say that we would transform it from mechanics into mechanics.
08.05.2020 20:18 # 11
ggitaristt
[QUOTE = sdttn]
I don't think my master is so talented .. But you are right mechanic ..
Mechanic = No need not be a problem?
08.05.2020 20:18 # 12
aslan
When the vehicle runs in the morning, when you turn it to the right and turn it to the left, it is the black steering wheel that you know, but it is just a bit of stuck when you turn it to the left, but it does not click with a lot of force, and the pump comes into play. This problem is happening, but when I turn it to the right I don't understand, it is very rare. I almost did not do this problem at all, I asked the oil in the oil change, the same thing happened in the lubricant, as if there were metal crumbs, there is a problem in the left front of the vehicle. When it goes slowly, it gets light to the brakes, it does not sound when it is fast, it does not make it in turns. Confused Actually, I am not afraid to come across to the master who does not understand the problem, not the fear or money.
08.05.2020 20:18 # 13
horoz28
If you do not buy my brother, I have a pump from my 206 1.4 gasoline car.
08.05.2020 20:18 # 14
Sefa0506
Turn heads say the car's axle and push rod if space also makes him a lot hope you do not hold anything
Sefa0506 2017-05-11 17:35:52
08.05.2020 20:18 # 15
zerzevat
what's the result?
Sometimes the carpet mat slips around the missing steering knuckle .... I had it. It is useful to pull back the mats every two days ...
08.05.2020 20:18 # 16
Futura
Goodnight
15 days ago very clean 2000 model 206xr 1.4-75hp. bought auto gear peugeot. Is this model's windshield automatic backs manual and the backs automatic?
Do you also have ABS?
How do you understand?
08.05.2020 20:18 # 17
eng uzn
[QUOTE = Futura] Good night
How do you understand? [/ QUOTE]
If the yellow ABS lamp is on when the ignition is on, there is two seconds abs. eng long 2017-05-15 08:56:01
08.05.2020 20:18 # 18
First of all, welcome to us. I wish you to use your vehicle without any accident, good luck. The rear windows can be made electric, but because of the lining it is expensive, I think don't bother because it costs a lot, because if there is abs, look at the indicator lights while starting the car. I am uploading this picture in the engine section.
08.05.2020 20:18 # 19
Futura
Thank you so much
08.05.2020 20:18 # 20
aslan
[QUOTE = vegetables] what was the result?
I haven't done a result yet Big smile only the steering hydraulic oil was very bad, I pulled the old oil with my own facilities and completed the new one. Smile
Page : / 2
