new tire rubs into the rear fender |
| • Homepage » PEUGEOT MODIFIED PLATFORM » Peugeot Wheel Tire Selection | |
| 08.05.2020 15:06 | # 1 |
I bought 15 "wheels for my 206 vehicles, arrived today and assembled with new tires. This rim stands a little further out compared to old hair rims and my old size was 185/65/14. rear tire rubbing into the fender while trying to bury it inside the fender |
| 08.05.2020 15:06 | # 2 |
I think the offset is too much ... you can solve the problem by opening the fender. When buying rims, it is necessary to pay attention to meat value
| 08.05.2020 15:06 | # 3 |
Where did you get the rims, is there a link?
| 08.05.2020 15:06 | # 4 |
There may be a problem with the wheels that should not rub on the 55 sidewall tire, but the rubbing you say is on the 65 sidewall tire.
| 08.05.2020 15:06 | # 5 |
Muhammet CAKIR |
The surtme is the plastic of the mudguards. 195 * 50 * 15 even when I was going to surtuyod, it was gone and the sound was gone.
| 08.05.2020 15:06 | # 6 |
rim cms 560 model i guess 15 offset. There is no hood in the rear fender, but there is a curl around 1 cm. I think it rubs there :( What exactly did you mean when you said opening a fender? |
| 08.05.2020 15:06 | # 7 |
more precisely offset 6.5j, I think it will be Et15 |
| 08.05.2020 15:06 | # 8 |
good choice good luck good bye I have no knowledge about it, I hope hallolur meanwhile, how much did the wheels cost?
| 08.05.2020 15:06 | # 9 |
I also thought about this rim, and now I was offset. |
| 08.05.2020 15:06 | # 10 |
Muhammet CAKIR |
[QUOTE = manyaq_motorc of] rim cms 560 model i guess 15 offset. There is no hood in the rear fender, but there is a curl around 1 cm. I think it rubs there :( What exactly did you mean when you said opening a fender? [/ QUOTE] we need to detect the good part of the gutter, while the mudguards open, our friend suggested that you pull the mudguards outwards. |
| 08.05.2020 15:06 | # 11 |
Thank you, my friend, I bought the rim very well, but it was pretty good, but here is the rubbing problem: |
| 08.05.2020 15:06 | # 12 |
As far as I understand it comes to the flipping place of the fenders. If you shave those parts, the problem will be solved or it will exhaust them with a hammer. |
| 08.05.2020 15:06 | # 13 |
I think it wouldn't hurt to bend that part in. Am I wrong?
| 08.05.2020 15:06 | # 14 |
you can even do it yourself;) smk the rubber, take a hammer in your hand. There is a fold in the fender. Hit it there until it's crushed. No, if you don't want to do it too, take a rocket. shave it, let it be finished;)
| 08.05.2020 15:06 | # 15 |
we bent that part inside, but when 3 people were sitting in the back, they bumped a little and stretched a little too little.
| 08.05.2020 15:06 | # 16 |
Nothing can happen from a little;) 1 person in my car, sit in the middle and keep going;) |
| 08.05.2020 15:06 | # 17 |
does not rub the tire damage the tire ??
| 08.05.2020 15:06 | # 18 |
If it is peeling in stretches, it does not give much. If 5 people are constantly getting into the vehicle, it is necessary to find the location and take action accordingly.
| 08.05.2020 15:06 | # 19 |
It is understood that when the upper part of the fender is already visible, the tire will not fit in that fender. This would not be the case if the Wheel had a value of 25 instead of 15. I think 2-day wheels are wasted |
| 08.05.2020 15:06 | # 20 |
The rim did not go to waste my brother;) surten the place with hammer, sledgehammer like crush
