New member new vehicle chronic problems
08.05.2020 21:14 # 1
Ugurdaghan
Selamin selamin aleykum ...
I have 15 days 2003 307 sw.
As I got to know the vehicle, I started to love it, especially the width and the comfort ...
The reason I open the subject is to be able to handle myself as much as I can, not to feed the ignorant masters to better understand the problems of the vehicle.
The missing parts of the vehicle ...
1_ the windshield grille was cracked filled with silicone. I bought a new one and fixed this problem quickly.
2_ left glass opening group was not working well. I stuck it, cleaned it, but when a nail was broken, I did not get it, so I bought a new side industry. It was easily resolved in this problem.
3_ glass water does not work ... I have inserted the engine, it works when it is tested outside, but it does not work in place .. Is there an electrical problem? ...
4 _ automatic gear shifts from 1 to 2, often by raising the speed and knocking. No problem with other gears, I had read in another forum on this site, the friend was pretty nice but when I called the service yesterday they charged 600 TL for the oil change .. I think it seems that we will go to the service for this job ....
5_ My glass ceiling is cracked, how can I supply it at a cheap price ...
6_ glass roof curtain does not work. When I look at the int, I found the nail set, it seems easy to make, but if there are points that I should know about beforehand, I would like to learn because the big glass ceiling is the reason I bought the car ...
7_ A creak is coming from somewhere from ten sides, something is knocking on each other under the glass, but for now, I don't understand.
8_ Park Senroru Not Working. .. I couldn't take care of him yet
9_ top info screen doesn't work either ... i think it will work when you get a new one, and if you have a real knowledgeable master near opium and nearby you can recommend them if you are hungry ...
I would like to thank everyone who responded in advance. ...I
the Ugurdagh 2019-05-24 16:43:47
08.05.2020 21:14 # 2
Hello, hello.
1-Unfortunately, the masters do not pay much attention to the bakelite part while performing maintenance, it is broken or deformed from exposure to factors such as the sun continuously.
In 2-ten, the reason is that in the rainy weather, the glass angle water comes directly to this button group. For some reason, the button becomes inoperable, of course, not everybody, we can disassemble and clean it, apply pressure, or something is breaking.
3-There are two possibilities my teacher, one of them is either the headlight signal arm that is chronic or the fuse can be common with other electrical parts.
4-Does this matter if the engine is hot or cold. Or does it just make the engine hot? they only gave a very high price for oil change, although 50 liters per liter is 50-60 tl, they can put 5 lt of oil at most. In full automatic, not all oil change can be done, complete transmission must be distributed.
5-glass ceiling work will be a little costly. zero price can be around 4000-5000 TL. we have to ask the particles.
6-Glass ceiling curtain repair There was a topic in the relevant forum, teacher. this repair was done by a master in izmir.
7-The sound may be related to the front team.
8-parking sensor eyes may be damaged, you can order sensors from China again, I hope the parking assist brain is not defective. otherwise, those who want around 500-600 TL can be.
9-You can order from China as you say.
08.05.2020 21:14 # 3
Ugurdaghan
Thank you very much for the answer .... I inserted the ceiling curtain completely on Sunday. My goal was to look at the state of the curtain mechanism ... I took it down completely while I took it and the mechanism ...
Of course, an undesirable situation came out and the fabric was scattered while the ceiling curtain was getting old. And the cost of the flooring has entered the job. but whatever the wisdom film shooters were, they were a bit reluctant to film the film on the cracked glass. When I say I do it, I keep the number high ... I finally agreed with a master, bring it to tomorrow. the takabilecekmi ...
08.05.2020 21:14 # 4
there is a related subject, hojam.
https://forum.peugeotturkey.com/forum_posts.asp?tıd=41626&title=307-sw-cam-tavan-perdesi-bakim-ve-tamiri-nasil-yap
sonerkyl 2019-05-28 13:46:34
08.05.2020 21:14 # 5
Ugurdaghan
Thank you very much for your interest and interest. After I started with two issues that you provided .link, I had read the videos before. I have already examined the videos.z already decided to switch after that ... God bless these two friends. ..If I had found the same advertisement, I was looking for the man but the ceiling mosque, which was not in his hand, was quite old in this advertisement.
As I fix the gaps, I try to write from here ....
Next is the oil change after the holidays ...
