new generation of american parking module
Homepage » PEUGEOT MODIFIED PLATFORM » 307
08.05.2020 18:58 # 1
byderebey
Hello friends .. I want to bring an open-close American parking module set to my vehicle ..
My question is: 1: Is there a problem in this module, such as the module and the lamp getting warm, are there any friends who use it?
2: I brought a parking sensor a few days ago, I installed it in the car. Can I install this American parking module?
08.05.2020 18:58 # 2
KuzuX
Well, for years, I used an American park neither the bulb exploded nor the bulb warmed. When it comes to the second problem, you can look at the scheme on the internet, but if you were me, I wouldn't risk taking the electrician.
08.05.2020 18:58 # 3
byderebey
Thank you very much, brother. Actually, I looked at the scheme from the Internet and it has no difficulty. The guys who have all explained in a detailed way. Also, if I think of something I can do myself, it is difficult to give money. For example, they asked for 50 liras to install the parking sensor. The piece is already 30 lira. There is no mercy in the industrial trades of our country.
08.05.2020 18:58 # 4
Alicilik
Make a simple control pen 12v. With it, just find the + end of the parking light of the vehicle and the 4 end of the 4f. Cut the rest bic
08.05.2020 18:58 # 5
samet206
There are assembly schemes, you can do it easily, but some models use stone resistances or something similar, or vice versa. You can capture the image of the American park, not only your fender signals will burn, but the image is beautiful.
08.05.2020 18:58 # 6
byderebey
I will not touch the fender signal anyway. I only think that if the parking lamp changes, the headlight will light up on the inside, but if the module is installed, the signal lamp will be more pleasant on the side. Thank you for your idea anyway
08.05.2020 18:58 # 7
serdaralisan
Well, friends, the model signal is separate from the first chassis of the vehicle, I opened a hole on the side, I opened the normal signal bulb. No need for a module flange: D
