New generation led xenon bulb
08.05.2020 20:44 # 1
ocaliptus
Hello friends,
I am thinking of buying a new generation led xenon bulb for my 2006 model Peugeot 407 1.6 hdi vehicle. If there are friends who have taken and used before, I would like to learn their opinions and thoughts.
Thanks in advance ....
08.05.2020 20:44 # 2
samet2461
I have been using for about 1 year in my 307 vehicle both long and short. I bought Nighteye brand fan 9000lum aliexpresst. I am very pleased. I recommend you too
08.05.2020 20:44 # 3
ocaliptus
Thank you. I will also buy from AliExpres, I wonder whether the 407 headlight structure is suitable. I wonder if the headlight lenses cut the light or not. Do you think the 307's headlight lens is the same?
08.05.2020 20:44 # 4
samet2461
My vehicle's headlight is lensless. It illuminates just like normal xenon. I don't think there will be a problem with your vehicle.
08.05.2020 20:44 # 5
ozkantuning
I put on my 307 vehicle with a 2006 lens and I did not understand what power is weak or not.
08.05.2020 20:44 # 6
onlycihan
I put it on my 206 car yesterday.I put it on short, it gives a more intense light, but if the places are wet, it does not give much efficiency.
08.05.2020 20:44 # 7
maximusti
I have been using it for 1 year, I bought it from aliexpress C6 brand, I am very satisfied with its lighting,
there are xenon headlights in the short, it does not appear in the rain at all, but it illuminates well when it goes on long,
I guess it would also better illuminate with lenses.
08.05.2020 20:44 # 8
samet2461
[QUOTE = ozkantuning] I put it on my 2006 lens with 307 and it is weak.
Some led xenons do not fit well in the slot or do not measure correctly. Therefore, it cannot transmit the light on the road correctly. I had that problem. Now I'm using nighteye brand. I can say brighter than xenon. In addition, it does not damage the reflective surface inside as it does not heat up as much as xenon.
08.05.2020 20:44 # 9
ocaliptus
Is the xenon in your car normal xenon or new generation led xenon?
08.05.2020 20:44 # 10
ocaliptus
My 407 also has a short lens. I was curious about it and felt the need to open the subject. I think I'll give up.
08.05.2020 20:44 # 11
samet2461
[QUOTE = ocaliptus] Is xenon in your car normal xenon or new generation led xenon? [/ QUOTE]
The new generation of led xenons with fan on the back. One of the led xenons that make lightning effect. I use both short and long. Short H7 long H1. It is great in lenses
08.05.2020 20:44 # 12
ocaliptus
Are you experiencing lighting problems in rainy weather or black asphalt?
08.05.2020 20:44 # 13
samet2461
[QUOTE = ocaliptus] In Shorts Do you experience lighting problems in rainy weather or black asphalt? [/ QUOTE]
I have no problems. Layer better than helogen bulb
08.05.2020 20:44 # 14
ocaliptus
Thank you. I looked at the brand you said from AliExpres.
08.05.2020 20:44 # 15
samet2461
[QUOTE = ocaliptus] Thank you. I looked at the brand you said from AliExpres. [/ QUOTE]
I used it for a long time, you won't regret it. What we bought yesterday at your friend seat leon put on a room he said better than xenon. I thank you. samet2461 2018-01-23 11:59:48
08.05.2020 20:44 # 16
ocaliptus
What is the lumen value of the bulbs we bought
08.05.2020 20:44 # 17
samet2461
[QUOTE = ocaliptus] What is the lumen value of the bulbs we bought [/ QUOTE]
9000lü financing
08.05.2020 20:44 # 18
ocaliptus
I bought 9000lm, but the seller did not ship the cargo for 3 days, I canceled I will receive 12000lm.
08.05.2020 20:44 # 19
samet2461
[QUOTE = ocaliptus] I also bought 9000lm, but the seller has been 3 days not canceled, I canceled I will receive 12000lm. [/ QUOTE]
If it's another brand, don't let the lumen respond. It does not hold the length and does not light properly. I think you see 9000 lm at night again
08.05.2020 20:44 # 20
onlycihan
H7 infitary LED bulbs, which I have worn for the length of my 206 cars last Sunday, had the opportunity to try and compare well on a 60 km journey tonight. It is true that they call lightning effect, the moment bursts by burning, just like the light that occurs while welding. But when I burned the lengths in old halogen headlights or made a selector, it illuminated to make a forward focus like an arrow. I was looking far ahead without the scatter of light. With the leds, I realized that the distance between the selector or the high beam was a much wider distribution of light, and that the distance to the forward fell very much. If the road is empty and there is no object to hit the light, it is not very good, but a better view is formed when passing through forest areas. In short, halogen Lee provided further illumination while traveling on deserted roads that burned the lengths while performing the selector duty.
Page : / 2
