New 3008 MyPeugeot Disconnected
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 3008 (2016-)
28.01.2021 22:38 # 1
safa.faz
Good afternoon everyone. We bought the new make-up case Peugeot 3008 Allure. 2021 model. I can't connect it to MyPugeot application. What is the problem? The phone is iphone7.
29.01.2021 10:48 # 2
Ozdemirli
Unfortunately, this program does not work very stable. I succeeded sometime, but now when I install the latest update of the application, the data does not flow to the teleton, although it says CONNECTED TO THE VEHICLE. I can recommend the following:
1. Delete and re-pair the car and phone bluetooth pairing.
2. With Bluetooth off, try making a connection via USB with the phone's original cable t .
3. Then open the MyPeugeot application.
4. With the app open, turn on the bluetooth signal of the phone and connect to the car via bluetooh.
5. MyPeugeot Connectable to Car warning will appear on the mobile phone's notification screen. Click it and let the app connect.
6. Do all this in a place with a cell phone network.
7. After 5-6 seconds, in the MyPeugeot application, a light blue band will appear at the top and the text VEHICLE CONNECTED. span style = "font-size: 11pt;">
as I said, the program is not very stable. There are some who have tried these steps many times and succeeded in the end, and there are also those who can connect to the vehicle not every time.
29.01.2021 22:55 # 3
safa.faz
Thank you very much. I will try your suggestions and give you feedback as soon as possible.
03.02.2021 09:14 # 4
Unfortunately, peugeot, this is troubled teacher, I hope you will solve our problem. They cannot do it even in authorized services.
11.02.2021 22:25 # 5
safa.faz
[QUOTE = Ozdemirli] Unfortunately, this program does not work very stable. I succeeded sometime, but now when I install the latest update of the application, the data does not flow to the teleton, although it says CONNECTED TO THE VEHICLE. I can recommend the following:
as I said, the program is not very stable. There are some who have tried these steps many times and succeeded in the end, and there are also those who can connect to the vehicle every once in a while.
May God bless you, my master. I did what they said sequentially, I do not know if I say chance, but the application was connected in a single, I was struggling for 2-3 weeks. My problem has been solved and now it works smoothly. The application is stable. Thank you very much &# 128591; &# 127995;
14.02.2021 18:54 # 6
Ozdemirli
[QUOTE = phase.phase] [QUOTE = Ozdemirli] Unfortunately, this program does not work very stable. I succeeded sometime, but now when I install the latest update of the application, the data does not flow to the teleton, although it says CONNECTED TO THE VEHICLE. I can recommend the following:
May God bless you, my master. I did what they said sequentially, I do not know if I say luck, but the application was connected in a single, I was struggling for 2-3 weeks. My problem has been solved and now it works smoothly. The application is stable. Thank you very much &# 128591; &# 127995;
I am very glad, teacher.
I also recently worked with Android Auto :) but it may be one time. We will see ..
