New 2008 left front sound
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 2008
27.09.2020 11:16 # 1
Murat062
Hello friends. I just joined you. Ever since I received my Zero 2008 vehicle, I hear the sound of lok lok from the left front, especially on bad roads. It's annoying to hear such noises from the new car. Everyone getting into the vehicle notices the sound. Has anything like that ever happened to the press? In addition, the suspensions of these vehicles are so stiff that they shake people on slightly rough roads. I saw a stiffer suspension tractor than this one, and there was no suspension on it :) I am waiting for your suggestions. Thanks
29.09.2020 13:35 # 2
GKTG
Greetings. I am also a 2008 user. I bought my car zero months ago. I do not hear any noise. Regarding the suspension stiffness, it was a bit harder than the 3008, but it is not bad enough to compare with the tractor. The problem seemed special to you, if you wish, take it to a workshop. Finally, compared to the first time I bought the car, the stiffness in the suspension decreased slightly. Friends with knowledge on this subject can write. I am very pleased with its comfort and silence right now. 🧿
29.09.2020 15:49 # 3
Murat062
Hello. First of all, get on your car on good days. Let me ask something while I catch you :) In shifts from 1st gear to 2nd gear, carting happens especially when the cycle is high. It is as if the clutch is not disengaging or releasing it late. Does something like this happen to you? Also, do you have information on whether the tire pressure sensors of these vehicles are integrated into the valve or abs system? If it is on valves, is there a problem in changing winter tires? Sensors connected to the valve are said to be sensitive. I heard that the slightest mistake was damaged in tire changes. As for the sound problem in my vehicle, the tire pressures were quite high, and when I adjusted them, it decreased a little. However, it still exists. A friend of mine said the sound was coming from the front hood. Sometimes I notice the hood wobbling on rough roads. Maybe I use it on very bad roads, I don't know. In short, when we buy a new car, people get upset. There is no authorized service in my city. The nearest shuttle is 150km away. Thank you for your attention.
29.09.2020 16:52 # 4
GKTG
Thank you for your good wishes. Use your vehicle on good days. The sensors are not in the valve that I understand from the manual. We do not use snow tires because we live in Antalya. For this reason, I have not had a situation like resetting yet. The EAT8 gearbox does not feel anything when shifting from 1st to 2nd gear. If you pay attention in 3rd gear, it just feels like it's throwing a little forward. But it feels hard to understand if you don't pay attention. We did not have a similar situation with the hood. I went up to 195 km / h, there was no movement that caught my attention at all. I hope they are simple problems and they can be solved in a short time, I could not help you much. Nevertheless, do not bother you, mechanical tools of the servant structure, there is definitely a solution that I rely on peugeout both as suspension and transmission. Stay healthy,
29.09.2020 23:08 # 5
Murat062
Thank you so much
26.01.2021 14:40 # 6
ahmetdogu
I had a similar problem with my 2008 GT LINE vehicle. This problem occurred while cruising on a curb stone road at a speed of 10 km, and this sound is heard from the front of the left, and LIK LIK was like a metal crash. I have been keeping records since the day I bought the vehicle. When I took it to the service for the solution of this problem, they first changed the shock absorber without understanding the problem. However, this was not a solution. Afterwards, they said that the headlamp was dislodged according to the determination of whether I had hit the vehicle or not. :) I said such a situation is not possible. The problem was solved a little after the intervention, but still that voice comes from time to time. :(
