needle problem
08.05.2020 16:33 # 1
GiTaRRa
I've noticed for a long time, friends. I press the throttle, the needle goes up to 5 thousand, I leave the gas and press the clutch, the needle remains stuck 3 4 seconds later.Is there a problem with my normal or gas reaction.
08.05.2020 16:33 # 2
yavuz25
Doesn't it move in parallel with the engine speed?
08.05.2020 16:33 # 3
djchaos
flow meter error or manifold leak
problem with idle valve, throttle problem or contamination, speed sensor error, these may be a problem. ??
http://www.youtube.com/watch?v=Pn9jNka3D7I&feature=player_embedded
08.05.2020 16:33 # 4
djchaos
[QUOTE = GiTaRRa] I have noticed for some time, friends. br /> we can help you more if you write the features of your vehicle
08.05.2020 16:33 # 5
GiTaRRa
It moves in parallel but falls to its normal speed after 3 4 seconds. It looks like in the video, but it is not complete. It falls slowly. Mine shifted at 4 thousand. It stops and it comes down in a moment. It is not like it is just stuck. Then it passes for 3 or 4 seconds. .
The throttle was cleared, I don't think it could be from him.
08.05.2020 16:33 # 6
GiTaRRa
106 xr 1999 model
08.05.2020 16:33 # 7
GiTaRRa
current
08.05.2020 16:33 # 8
altantezcan
I have the same thing, even when I first bought it, I was quite skeptical, but a friend of mine sets the speed itself, so it changes at the same speed for 2-3 seconds when changing gears so I think we can continue from the same speed when we shift into gear, this is something like this
