need help with tire air
08.05.2020 15:42 # 1
eren8er
my car 106 quiksilver .. my tire dimensions 175 - 65 - 14 how many air do I need to press? everyone else says something ... what exactly is the standard of it? Actually these tires do not fit my vehicle at all, but I manage until I get a new tire. eren8 is 2011-06-25 22:29:41
08.05.2020 15:42 # 2
30 flaws I size 195/55/15 I hit 33 orj 30 or 33
08.05.2020 15:42 # 3
eren8er
let me check the tires before going to meet tomorrow .. since i print 30 .. thank you ..
08.05.2020 15:42 # 4
[QUOTE = eren8er] my car 106 quiksilver .. my tire sizes 175 - 65 - 14 how many air do I need to press? everyone else says something ... what exactly is the standard of it? Actually these tires do not fit my vehicle at all, but I manage until I get a new tire .. [/ QUOTE]
The reason why everyone says something else is due to any formula (a) in May. Because many parameters determine the amount of air you will hit, for example comfort, road handling, sound, tire brand ... etc. It also depends on how much air is in the car, the weight of the car, how fast you seek comfort. Therefore, the amount of air varies according to the user provided that it is within the limits recommended for the tire.
08.05.2020 15:42 # 5
you are welcome it is not important
08.05.2020 15:42 # 6
metin
What should be the normal air of the 307's 195/65/15 tires (:
08.05.2020 15:42 # 7
[QUOTE = text] What should be the normal air of 307's 195/65/15 tires (: [/ QUOTE]
With no weight, 2.4bar ~ = 35 psi on and back.
Koliva 2011-06-26 07:54:55
08.05.2020 15:42 # 8
For 175/65/14 rims No front and rear 34 psi when the vehicle is loaded Front 34, rear 35 psi with the vehicle loaded.
08.05.2020 15:42 # 9
metin
[QUOTE = koliva] [QUOTE = text] What should be the normal air of the tires of 307's 195/65/15 (: [/ QUOTE]
brother, I pressed 30, it sounded like 35 is not so much (:
08.05.2020 15:42 # 10
[QUOTE = text] [QUOTE = koliva] [QUOTE = text] What should be the normal air of the 307's 195/65/15 tires (: [/ QUOTE]
Not Text. When it is up, the back is hit more.
It already writes on the pillar of the door of the Sofor. Don't you have that sticker?
08.05.2020 15:42 # 11
My old car was also 106 Quik, can you drive with 175-65-14 tires? The fronts were rubbing right or left. It is also suitable for 30-31 o tire as tire pressure.
08.05.2020 15:42 # 12
GokhaN
Pressing 30. Recommends 30 to all tire manufacturers if not commercial vehicles. It greatly reduces the amount of stretching in tires over 32. The rubber becomes like rock and the comfort decreases a lot.
08.05.2020 15:42 # 13
eren8er
[QUOTE = Berkay] My old car was also 106 Quik, can you use it with 175-65-14 tires easily? The fronts were rubbing right or left. It is also suitable for tire pressure of 30-31 o. [/ QUOTE]
I can not use it comfortably ... when I break it to the left and left, it does rub. Yes .. I will change it.
08.05.2020 15:42 # 14
metin
[QUOTE = coliva] [QUOTE = text] [QUOTE = coliva] [QUOTE = text] What should be the normal air of the 307's 195/65/15 tires (: [/ QUOTE]
Brother, my car has a sticker, but it says 205/55/16 as a tire, 2.5 bar is installed on the tires, it says 2.7 bar at the back, I pressed 30 psi since my tires are 195/65/15 (I think it corresponds to 2.06 bar)
08.05.2020 15:42 # 15
it is even called 29 ideal in hot weather in summer. That's what my master said to my 195-50-15 tires
08.05.2020 15:42 # 16
Friends, even if you calculate the inside doors of the vehicle, this size corresponds to 34 psi. Also, there is a table under the air press machines in gas stations. In this table, all tire dimensions and pressure amounts write 34 psi for 175/65 14 wheels even in that table. For 30 psi 165 tires. I was using this size in my previous car and it was 30 psi.
08.05.2020 15:42 # 17
For my vehicle (307 SW), it is aimed to hit 2.4 bar (~ 35 psi) on them and the rear while it is high, according to the writer on the door post. In the loaded state, the back is hit more.
http://www.tyre-pressures.com/bycar/peugeot/307
You can find your own vehicle from the site and find out the recommended amount of air. He says the same values for my car:
Tire Size Front tires Rear Tires
195 / 65R15 H 91 2.4 BAR / 35 PSI 2.4 BAR / 35 PSI
08.05.2020 15:42 # 18
metin
I frightened it to bounce (:
08.05.2020 15:42 # 19
I'm 185/55/15 Sizes I'm Pressing 30 Because My Tires Are Sports ...
Once I Was Pressing 32 The Car Was Logs Officially ..
08.05.2020 15:42 # 20
[QUOTE = text] I'm scared that it will boil down (: [/ QUOTE]
The following article is from bridgestone site:
http://www.bridgestone.com.au/tyres/passenger/care/pressure.aspx
[QUOTE]
Believe it or not, checking your tire pressure can have a big impact on our environment. An under-inflated tire creates more rolling resistance and therefore more fuel consumption . By keeping your tires inflated to their proper levels, you can help maximize your car`s fuel economy and minimise its impact on our environment.
He says;
Believe it or not, controlling the air pressure in the tires has a huge impact on the environment. Tires that are less inflated have greater frost resistance and result in more fuel consumption. By pressing the right level of air into your tires, you will help fuel economy in your vehicle and less impact on the environment (pollution).
Page : / 3
