Navigation Update
08.05.2020 21:11 # 1
samizeldestan
When I want to open the navigation in my 407 vehicle, it asks me something like the application path. How can I run and update this navigation
08.05.2020 21:11 # 2
x571
It was a story. Never try to load igo on your mobile phone or upload maps to Google Map ofline. Because you will find a pirated Map for your vehicle and you will update it. Also, as before, no one is sharing a pirate Map.
08.05.2020 21:11 # 3
samizeldestan
Thank you. Well, it would be best if I took something like a tablet and loaded Google maps because
08.05.2020 21:11 # 4
x571
[QUOTE = samizeldestan] Thank you. Well, it would be best if I take something like a tablet and load Google maps because [/ QUOTE]
Exactly. There is also a smartphone that you do not use. I'm doing that.
08.05.2020 21:11 # 5
gecegoz
[QUOTE = samizeldestan] I want to open the navigation in my 407 vehicle and it asks me something like the application path. How can I run and update this navigation [/ QUOTE]
Master, what is the system in the vehicle ... ???
rt4, rt5, Rneg or whatever else. If you say it exactly, we can have a benefit ..
08.05.2020 21:11 # 6
samizeldestan
Where can I learn it?
08.05.2020 21:11 # 7
ocaliptus
Don't bother with navigation, just use Google Maps or Yandex Maps. It is enough if you connect and update the internet every 6 months.
08.05.2020 21:11 # 8
samizeldestan
I will probably do so. Because there is no more updated than google navigation. Then comes yandex. Google navigation will also be super if it shows radars etc.
08.05.2020 21:11 # 9
samizeldestan
I just ran the navigation while I was just tampering, but there is a problem that says GPS signal is being searched but for some reason it does not find it. So location doesn't work. At the same time, what kind of a problem does it not find in radio stations? Everything else works
08.05.2020 21:11 # 10
ersin61
Dude there is a leak on the antenna, it does not receive a signal. Also there may be a separate antenna for the gps.
08.05.2020 21:11 # 11
samizeldestan
So, can I describe where the vehicle is in two antennas?
08.05.2020 21:11 # 12
ersin61
The original radio antenna on the ceiling is usually placed in front of the glass because the navigation gps antenna is retrofitted.
08.05.2020 21:11 # 13
_____YZG_____
we put the door directly inside the multimedia akaken. yours may be in that area. rarely, tape can be placed on top. you have to take it out. GPS antenna is around 75 TL.
08.05.2020 21:11 # 14
Aslan besleyici
https://www.facebook.com/karatutlu/videos/10217256457301636/
Look, I do it myself if you want a brother
08.05.2020 21:11 # 15
samizeldestan
I watched the video I wonder how much it cost
