navigation problem
08.05.2020 16:45 # 1
marjinal44
slmlar friends I just joined you 1.6 tecnoplus 2004 have aegean blue 307 I cannot establish any kind of GPS connection in this vehicle. When I take it out of the window, it pulls out, the GPS signal disappears after 2 minutes when I put it inside the vehicle. I removed it from the rain and its persensor again the same problem
08.05.2020 16:45 # 2
Alicilik
The windshield of your vehicle is a special glass. I don't know the name exactly, but this glass blocks the signals. Because of this, you cannot receive a GPS signal under the glass.
If you buy a special GPS device and install it in a place independent of glass, you can operate it.
08.05.2020 16:45 # 3
toga406
my friend I have 406 too. My priority is the sub-industry. sensors do not work. rain and light sensor. In the service, they said that the windshield side industry could be from him. I think your problem from glass
08.05.2020 16:45 # 4
metin
I don't think it will be related to glass. I also had the 307 XT, a thermal windshield with a sensor, but navigation was not only in tunnels. There may be something else in the vehicle that is breaking the signal. & Nbsp;
A similar event happened to another member before. The former owner of the vehicle had something installed for the automatic garage door. It is constantly emitting a signal and the door opens automatically when it approaches the house. The problem disappeared when the man noticed and dismantled this device. This may be the same.
08.05.2020 16:45 # 5
Alicilik
Metin master,
Jammer and different signal emitters can block the GPS signal, but there are special glasses that both break the sun and affect such signals. That's why there are those who wear a GPS antenna. Technoplus is & nbsp; I think it will be sourced from the windshield. If a signal is spreading, it will spread like a globe, and the device will not be connected to the satellite, either in the car or around the car.
If I have a navigation device, I would say try it on sunroof or on side windows and butterfly glass. When you want to get a film on the windshield, companies are asking this first.
08.05.2020 16:45 # 6
okan4037
teacher, my navigation antenna & nbsp; Connects in seconds at the corner under the leftmost ebn of the windshield above the torpedo
08.05.2020 16:45 # 7
marjinal44
thank you for your interest, if there is antenna navigation left, I guess I will buy from them now: DDD
& nbsp;
There is a 7 inch screen navitech tape, I suspect it too bluetooht & nbsp; I tried to shut it down because there might be a conflict. No benefit.
08.05.2020 16:45 # 8
I was very curious if the phone signals are falling too
08.05.2020 16:45 # 9
Alicilik
[QUOTE = marjinal44] thank you for your interest, if there is antenna navigation left, I guess I will buy from them now: DDD
& nbsp;
There is a 7 inch screen navitech tape I suspect it too bluetooht & nbsp; I tried to shut it down because there might be a conflict, no benefit.
& nbsp;
I suspect the glass as you say, thanks to me, let's be back
The double-din tape you use is external Certainly it has an antenna. Where did you put the receiver of this antenna?
08.05.2020 16:45 # 10
mestmes
hello the subject mentioned happened to me too. It was working with hard pulling and error margin of 100 meters.
