navigation peugeot 206, please help !!
08.05.2020 15:59 # 1
erdal
Hello everybody .. I want to get your opinion that I had a bad event today .. At the bend I entered at a speed of 80-90 at lunch time, my 206 cars slammed behind my back almost 4 times and I was able to stop the car with a last circle in the middle of the road. I did not experience anything before .. and then I realized that the back of my car was as if I was turning around after a long time, I do not know how to tell the back as it is walking, I am turning the bend, but it is like collecting it later .. What is the reason for having friends who have such an experience? erdal 2011-08-13 01:53:15
08.05.2020 15:59 # 2
I don't know exactly, but could there be a torsion failure in the back? or I don't know how tire weather. Is the tire shape the same or is it a different tire? also how is your tires status? it is useful to research them
Get well soon
08.05.2020 15:59 # 3
erdal
All of my tires are new, the tire air is normal, and the shape is the same. I know that clicks come when the torsion breaks. I don't have such a sound.
08.05.2020 15:59 # 4
deamod
I had no problems as much as yours, but there was a bit of tossing in me.
The problem was in torsion, right torsion bushes were trapezoid, torsion turned into lathe and bushings changed, the problem was solved.
Ask a friend to follow you with his vehicle for about 15 to 20 minutes and pay attention to the rear wheels.
08.05.2020 15:59 # 5
erdal
I have been facing what I've been afraid of since I bought the vehicle, I guess .. I hope the problem is not from torsion .. because I heard it was quite costly .. Thanks for the suggestions and ideas guys ..
the right front rot was broken but I guess it has nothing to do with it because I feel like knocking the back
08.05.2020 15:59 # 6
erdal
Have no idea friends :(
08.05.2020 15:59 # 7
erdal
So, friends, what are the symptoms of bad torsion .. click sound does it sound when the torsion is broken? Is there a connection of torsion with the vehicle's navigation? because there is no sound like a click or creak, just walking through the bend? Could z be linked to rot? please give an idea ..
08.05.2020 15:59 # 8
orhanetap
When I bought the vehicle, I had a problem with torsions. On the bad roads, it was making a sound like a tangur tungur tube car :)
08.05.2020 15:59 # 9
metin
Of course, it has to do with the z-rod. You shouldn't look for the problem in the back because it popped back. You should look at the z rods on the bend balance bar.
08.05.2020 15:59 # 10
Does the tool always react to this ??? The first thing you can do is give the tool to the good master and take the test ...
the cecol 2011-08-13 09:43:16
