Navigation Control
08.05.2020 20:05 # 1
Lucas
Hello friends, I bought a navigation for my car. There are some places that do not work on the remote control. Does anyone use this product or similar and solve the problem? The forward or back buttons do not work when I change the clip playing the sample and switch to another.
this is the product;
https://carvocal.com/peugeot-308-android-multimedya-navigasyon-sistemi-u-36.html
08.05.2020 20:05 # 2
dejawu1978
So I wonder what are you doing? Are you waiting for the clip to end? Big smile to switch to another dejawu1978 2016-12-19 22:16:17
08.05.2020 20:05 # 3
Lucas
I am talking about the control from the touch to the other.
08.05.2020 20:05 # 4
OguzhanKucuk61
Teacher, it is not related to your question, but when I saw it, I noticed something on the link. 1080p video support says for the product. This means a resolution of 1920x1080 pixels. But another line says 1024x600 pixels. It cannot pass HD. I could not understand. No problem if it has gotten into you.
08.05.2020 20:05 # 5
Now if my teacher plays radio or mp3 music transitions or something, other functions work like a trip computer, there is no problem. clip etc. because you will drive The driver may have been passive in order not to be distracted because the passenger will deal with the events. this is my opinion.
08.05.2020 20:05 # 6
Lucas
[QUOTE = sonerkyl] Now if my teacher plays radio - mp3 music transitions or something, other functions work like a trip computer, no problem. clip etc. because you will drive The driver may have been passive in order not to be distracted because the passenger will deal with the events. this is my opinion. [/ QUOTE]
My brother, the car is stopped, the problem is the same, the control is not a clip, it does not make it back and forth in mp3s, sound reduction, duplication works, mode change, cd usb etc. this is just working, the transition to the next track does not change to the previous track. Those buttons do not work, there is a part on the device such as key adjustment, but I could not solve it. Also, the trip computer does not show vehicle information.
Lucas 2016-12-20 09:52:11
08.05.2020 20:05 # 7
I understand, my teacher, the sound is working, but there is no transition between tracks. I wonder if there are problems with the back connections, which may be partly related to the settings. Well, did you get the device out of the sack?
08.05.2020 20:05 # 8
Lucas
[QUOTE = sonerkyl] I understand that the event you call my teacher is working sound but there is no transition between tracks. I wonder if there are problems with the back connections, which may be partly related to the settings. Well, did you get the device out of the sack? [/ QUOTE]
I bought the device from the internet, I was next to it when it was installed, 2-3 pieces of socket is probably not installed all the way because the sound reduction and duplication works but it does not work back and forth, there is a menu like this but I could not adjust it.
08.05.2020 20:05 # 9
Well, when my teacher comes to this menu, when you press and hold the keys, does the steering wheel icon appear as stated in the instruction?
08.05.2020 20:05 # 10
Lucas
Normally, the steering automatically came into prominence in the system, but now I press it again does not show any difference.
08.05.2020 20:05 # 11
I understand, if my voice actually works, it should work on other keys. I suggest you call carvocal.com and get information. device may need software update. or, as I said, there may be problems in the stingers.
08.05.2020 20:05 # 12
Lucas
I had a meeting with where I bought the trip computer etc everything ran from the settings, but they did not work back and forth again. the only place that didn't work was back and forth in which the canbus would change.
08.05.2020 20:05 # 13
I understand, we would appreciate if you inform me about the situation after my teacher arrived.
08.05.2020 20:05 # 14
Lucas
Of course I will try to get the canbus, I will write the full compatibility
08.05.2020 20:05 # 15
Lucas
New Canbus Has Arrived. We changed the remote control this time never worked :) We put the old canbus `` next '' again, everything worked, so we wondered, we said we could not fully sit the pins, it did not fit, we installed it in such a way. It will be installed flat and its cable will not be bent.
Compatible Canbus
Incompatible Canbus
Lucas 2016-12-26 13:30:00
08.05.2020 20:05 # 16
I'm glad your problem is solved, hodja. People get bored when they buy something new and have such problems. Use it again on good days.
08.05.2020 20:05 # 17
Lucas
[QUOTE = sonerkyl] I'm glad your problem is solved, hodja. People get bored when they buy something new and have such problems. Good day use again. [/ QUOTE]
Thank you bro, but if the problem is solved, you can directly master the issue from here;)
