my xenos cortted
08.05.2020 17:21 # 1
volkanC2
I asked if there was a problem in the examination the other day, yesterday evening I looked at the return of work. I went to the electrician, we tried the light bulb, then we tried a new balance (I learned that the box was called balancing) I tried the new one, but I did not get a new balance because I was not available and I got a yellow bulb 15 + 15 = 30 TL.
08.05.2020 17:21 # 2
cey cey
You get the new xenons from your owner, 60 tlye, if it is not an original thing, I manage it for 6 months, no problem, I think you gave 30 TL.
08.05.2020 17:21 # 3
Alicilik
Get well, hodja. If you think it is better, you do not have to worry about changing bulbs.
Also, the balance was wrong. It is a ballast, it is a voltage booster. Reviews
08.05.2020 17:21 # 4
Alicilik
[QUOTE = 307bursa] Did you add 30 TL to the light bulb? Brother, I gave the Philips x-treme visiona 70tl. H7 odd even "Smile". Reviews
08.05.2020 17:21 # 5
volkanC2
the guy was zero for 60 liras, but I did not know if one would work, and for the first time, I gave 30 lira to two yellow bulbs & nbsp; "Ermm" & nbsp; I am a little recovered, I hope I will get a balance, I will put the yellows in the trunk, I will need it in the examination, ultimately & nbsp; "Big
08.05.2020 17:21 # 6
Bugra
would it be 30 lira or yellow bulb "Shocked"
08.05.2020 17:21 # 7
volkanC2
[QUOTE = Buying] Get well, hodja. If you think it is better, you do not have to worry about changing bulbs.
Thank you. the yellow light came stronger than the bidet xenon.
08.05.2020 17:21 # 8
volkanC2
Is [QUOTE = bugrature] about 30 lira or yellow bulb "Shocked" [/ QUOTE]
Don't say
it sits inside me now "Big & nbsp; ; "Big
08.05.2020 17:21 # 9
Alicilik
[QUOTE = 307bursa]
Ali brother, you can find the brand you bought in a normal auto electrician. / QUOTE]
You are right when I decided to buy a brother, I was very frustrated. Maybe it is something that may be worth the price in the bulb that is attached to the car of your friend. Reviews
08.05.2020 17:21 # 10
volkanC2
I hope I did not look at the brand :) so that I will go to my house in the evening.
08.05.2020 17:21 # 11
suleyman2392
If you want two available, I can sell you h7
