My xenon on the right is blinking: S
08.05.2020 15:32 # 1
Burak07
The blinking of my car's xenon headlight on the right side is blinking after a while. There is no problem on the left side. I am replacing the left bulb.
08.05.2020 15:32 # 2
voodoo
Burning the headlights without starting the engine may have made a mess in the brain of the xenon, the headlights should be turned on after turning on the engine.
08.05.2020 15:32 # 3
tigerland
you will get a new bulb cut off. get well soon
08.05.2020 15:32 # 4
tigerland
How did I not understand how a minute bidkka ampn one did not burn, did you try to plug in the other side there? how did i not understand?
08.05.2020 15:32 # 5
Burak07
[QUOTE = voodoo] burned the headlamps before the engine started, if the xenon's brain may have mixed up, the headlights should be turned on after turning on the engine .. [/ QUOTE]
The result is still the same: S
08.05.2020 15:32 # 6
Burak07
[QUOTE = Erbin] I did not understand how a minute bidkka ampl one of them did not burn, did you try there on the other side and tried? how did i not understand? [/ QUOTE]
yes, I did exactly that, I removed the light bulb from the outlets and put it on the other one, and the result was the same bulbs again.
08.05.2020 15:32 # 7
tigerland
You tried the unburned bulb in the other brain, and if the result is the same, the bulb must have been cut, look carefully at the end, and it looks like it is broken.
Erb's 2011-06-05 22:01:51
08.05.2020 15:32 # 8
tigerland
What is your bulb type?
08.05.2020 15:32 # 9
Burak07
[QUOTE = Erbin] what is your bulb type? [/ QUOTE]
I use 4000K interesting thing is that there is a fracture on the left, but it is burning right, it is not burning: I don't know what to do
08.05.2020 15:32 # 10
tigerland
Test your brains with a working light bulb and get 2 spare bulbs if it is solid. Is it H7?
08.05.2020 15:32 # 11
dinoco
look at the ballast .. if your ballast is problematic, the new tactical bulb will be the same
08.05.2020 15:32 # 12
It happened to us in my brother's car. The xenon brain is malfunctioning. You will change your brain or cancel xenos and use old bulbs.
08.05.2020 15:32 # 13
tigerland
What do you not know, the manager did not try to plug it into the ballast brain running the light bulb? If it is next to the ballast that cuts the lit bulb, the brain is clean. you will get a double bulb 25 tl 1 month has been tested in the same way with trial and error method.
08.05.2020 15:32 # 14
ose
There may be no contact, so it was going to and from the right, taken from the chassis - minus pole screw loosened. The man tried with the other solid bulb, but not burnt?
08.05.2020 15:32 # 15
[QUOTE = Erbin] You will get a new bulb cut off. get past [/ QUOTE]
I agree with what you said I had such a problem in me, I had to buy a new one ....
08.05.2020 15:32 # 16
Sırıtma I started my car last night .. right headlight did not light up for half an hour then it turned on by itself .. still no problem Kahkaha we probably need to turn on the headlamps after starting the vehicle, and when we stop the vehicle, first we need to turn off the headlights and then stop ... Embarrassed
08.05.2020 15:32 # 17
Burak07
I changed my brain for 25 TL. The only right side is for now, I hope I use it for a long time. :) If Allah allows
08.05.2020 15:32 # 18
axi206
I got dun angel headlight and xenon. 8000k. right and left bulbs end at the same place, it turns on again after 1-2 seconds.
08.05.2020 15:32 # 19
[QUOTE = axi206] I got yesterday angel headlight and xenon.8000k. right and left bulbs end at the same place, it turns on again after 1-2 seconds.
If you immediately behaved Göz Kırpma Xenon bar for fog Gülme
08.05.2020 15:32 # 20
Burak07
Have a great history, no problem. S go to the electrician and test with other bulbs. Is there a problem in his brain: S
