My window fell
08.05.2020 15:24 # 1
nteker
Friends 307`s glass cracked. It's a big crack, it's not in the insurance. I poured water, water does not run in.
King auto said I can not, how much is the price of the sub-industry or the original. What if I use it like this?
nThe attached is 2011-05-09 13:36:06
08.05.2020 15:24 # 2
If you use it that way, it goes all the way to the edge. They open a hole to stop it from drying as far as I know. However, it is not very healthy to use it. Slight defect passes on inspection. I know that although it is possible to repair vehicles, it is not efficient. To change the most beautiful. Koliva 2011-05-09 13:45:08
08.05.2020 15:24 # 3
metin
realizes from glass to glass. There is a glass in 300 TL and 800 TL.
First of all, what is the model of the vehicle, because it detects on the 307 lenses with rain sensor without sensor etc.
08.05.2020 15:24 # 4
nteker
307 1.6 XR 2004 model
08.05.2020 15:24 # 5
metin
[QUOTE = koliva] If you use it like that, it will go all the way. They open a hole to stop it from drying as far as I know. I know that although it is possible to repair vehicles, it is not efficient. To change the most beautiful. [/ QUOTE]
It happens a lot because of the hot cold weather changes. For example, when the weather was hot, you turned on the air conditioner, it hit the glass, that crack walks. Besides, glassmakers do not recommend drawing. They say "walk from where we draw," they say.
08.05.2020 15:24 # 6
metin
you don't have a headlight rain sensor, probably not in the uv sunscreen protective film on the glass. so I don't think it will cost much.
08.05.2020 15:24 # 7
nteker
Yes, I guess, what is the estimate?
08.05.2020 15:24 # 8
metin
[QUOTE = nteker] Yeah no I guess, what is the estimate? [/ QUOTE]
Well, sponsor ŞAHİN-PEUGEOT will give you the price of the glass suitable for your vehicle from the chassis number and most suitable. He supplies the original parts.
08.05.2020 15:24 # 9
nteker
Thanks.
08.05.2020 15:24 # 10
I made glass repair for my friend. With a special machine, it injects the glass resin into the lens of the glass and it hardens with the UV rays. It prevents the hole to hurt and progress to the right end of the catlag.
If you see the cat in my vehicle, you will be stunned. I use it because I don't really feel it. After it was done, he never hesitated.
I did not change the glass with the sensor ... this way I went through the examination
the cecol 2011-05-09 16:48:39
08.05.2020 15:24 # 11
Friends, if I have a glass sensor with a casco, would I wear the sensor?
08.05.2020 15:24 # 12
metin
[QUOTE = pugti] friends, if I have a glass sensor with casco, do they wear the sensor? [/ QUOTE]
the sensor is not on the glass, only the sensor on the glass, that is, the sensor is removed before removing the old glass, after the new glass is installed, the sensor is mounted back.
08.05.2020 15:24 # 13
I know the sensor is a small box, but I think it is faulty. It doesn't work. I wonder if they could get him out. By the way, how is this sensor repaired? who knows this kind of thing?
respects
08.05.2020 15:24 # 14
metin
If the glass changes service, it does but adds to the price, if you change it outside, you can not already. How did you make sure the sensor was not working? The burner is disabled.
