My vehicle vibrates at the front of my car (SOLUTION) |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » All Questions About Your Vehicle | |
| 08.05.2020 16:20 | # 1 |
| 08.05.2020 16:20 | # 2 |
While turning right and left, it makes flow from head to head, if it makes a sound, but if it is shaking at a certain speed while on the road, it will be made from engine or transmission wedges. div>
| 08.05.2020 16:20 | # 3 |
My teacher did not even change the front team for 2 months:
| 08.05.2020 16:20 | # 4 |
[QUOTE = ercan_g] My teacher front team has not changed even 2 months: S but again the same [/ QUOTE] If you do not look at the heads of flow, because of the flow tulips or something, if you are doing this at the first departure, there is nothing else than a walker and a clutch pad.
| 08.05.2020 16:20 | # 5 |
teacher, I changed the axle to complete set. Complete zero org in clutch set. I think of engine chock: S but I'm not sure & nbsp;
| 08.05.2020 16:20 | # 6 |
[QUOTE = ercan_g] I changed my teacher axle to complete set. Complete zero org in clutch set. engine chock comes to my mind: S but I'm not sure & nbsp; [/ QUOTE] it is easy to test the first starter of the car, the engine is a bit If you shake or pull the handbrake of the car and recover the clutch, the engine will stretch a little too much.
| 08.05.2020 16:20 | # 7 |
I do it as you said, I try to pull the handbrake and get up: D The back of the car is reset and knocked on the ground like a lot of American movies.
| 08.05.2020 16:20 | # 8 |
[QUOTE = ercan_g] my teacher, I do as you say, I try to pull the handbrake and get up: D the back of the car is reset to the ground and it bounces like a lot of American movies: D [/ QUOTE] puts the car with the hand brake and picks it up, if you get a blunt sound, you'll probably change the gearbox or motor ears, as I said, if you don't have a control with the rocket lever, you can change it for a short time.
| 08.05.2020 16:20 | # 9 |
anybody with another comment :(
| 08.05.2020 16:20 | # 10 |
friends yupppiii: D I figured out the sound from the departure disappeared. The smell of gasoline inside my car was extremely extreme, it was more important to me and I told the exhaustman yesterday that I wanted to go and change the exhaust, said the man was the final muffler exaggeration, yes, I said it should be as big as a stovepipe. Complete replacement was made from the manifold outlet. I went on a test drive with the vehicle and I was distracted from the front team because it didn't come anymore: D I guess the manifold outlet wedge was troubled, but there are no more clicks in my car, but there are people who lead me when passing through the underpasses in a reversible way: D due to the stovepipe: D: D
| 08.05.2020 16:20 | # 11 |
& nbsp; no, but there are those who give me the way through the transitions in a cyclical way: D due to stovepipe: D: D [/ QUOTE] |
| 08.05.2020 16:20 | # 12 |
First of all, but be careful, at the end of those transitions, the red-blue light monsters set the stove on fire & nbsp; |
| 08.05.2020 16:20 | # 13 |
DRIVER34 |
I have the same problem, I do not care anymore & nbsp; 80000 maintenance, what is going to be done now ... & nbsp;
| 08.05.2020 16:20 | # 14 |
[QUOTE = csalli] First of all, but be careful at the end of those transitions Red-Blue light monsters set the stove on fire & nbsp; my teacher: D then I wasted right away, the gear doesn't sound: d: D custom handmade muffler .d
| 08.05.2020 16:20 | # 15 |
Correct it, friends said that the sound was coming from the catalytic converter of the vehicle. When I dismantled the old catalyst of my vehicle, the stones in it were broken and it was waste, so the exhaust.
