My vehicle syst antipol with defillant error 307 1.4
22.11.2020 16:42 # 1
34pejo34
My vehicle gave the syst antipollu défaillant error. I stopped after 3 5 km, then I start again, it seems like it gets and does not work. My vehicle is 1.4 petrol and no gas is installed. Can I have friends who can help? GökhaN2020-11-22 23:16:41
22.11.2020 17:48 # 2
ismailkaya
Best of all, you can find a solution after connecting to the computer and reading the error codes.
22.11.2020 21:44 # 3
34pejo34
A master connected it today and gave an ignition coil error. What happens? Do you know the cost?
22.11.2020 23:41 # 4
ismailkaya
The ignition coil price was between 550 tl and 750 tl last but the coil does not break easily, there may be cable contactlessness. If you do not want to remove the socket and re-insert it, you need to find a spare coil and try it. It would be illogical to get zero immediately. If it is one of the spark plugs, 4 spark plugs between 100 - 150 I guess except workmanship
23.11.2020 01:43 # 5
34pejo34
Thank you teacher, let's see what will happen tomorrow, thank you
24.11.2020 08:52 # 6
34pejo34
The electrician would somehow give the car electricity from the gas float and start it, but it seems to be clogged while going and does not eat gas and stops yesterday I stayed on the road twice yesterday, I disconnected the pole head and waited and then worked again. -11-24 08:57:00
