My Vehicle Stops While Cruising Help
08.05.2020 19:53 # 1
antep
Selam ALeykum
My vehicle 207 trdeny 1.4 hdi stops while driving, does not cut off electricity, just stops the engine.
Thank you from now.
08.05.2020 19:53 # 2
GokhaN
If the diesel vehicle is stopped while driving, I think it is related to the fuel system or injectors.
08.05.2020 19:53 # 3
antep
the tool has been 15 days. Do you have any information about injector prices?
08.05.2020 19:53 # 4
[QUOTE = antep] tool has been 15 days. Do you have any information about injector prices?
As our Gökhan friend said, it is about the fuel system. Have the diesel pump and injectors checked, replace the fuel filter first. When it comes to injector prices, they are repairing a figure like 500-600 TL, which is zero and it is guaranteed for 6 months. Repair of 4 injectors varies between 900-1200 TL.
08.05.2020 19:53 # 5
Meanwhile, when was the last maintenance of the vehicle. What is the error of the pc connect.
08.05.2020 19:53 # 6
antep
It was not 1000 km, the maintenance was not done. It is not a case like a motor mass. My head was completely cloudy. A friend of 206 who stood in his car was so sad after selling it.
08.05.2020 19:53 # 7
[QUOTE = antep] 1000 km has not been done, maintenance is not a case like motor massing, my head was completely cloudy, a friend of 206 stood in his car like this, 2 days after selling it, I was so sorry for the man who got the engine locked, my sleep fell away [ / quote]
When was the last time that triger felen changed? Motor locking can really be a lot of reasons. If the engine is locked, the vehicle will not start anyway. And how many km is the vehicle now.
08.05.2020 19:53 # 8
antep
the vehicle is now 167 thousand
08.05.2020 19:53 # 9
KILIC
I think the vehicle is good, I think it is related to the fuel system. Behind the industrial mosque, there is a gazikent pejo, there is a mehmetali master, there is a show for them, there is a righteous master there, but you may not find it.
08.05.2020 19:53 # 10
chakra
the crankshaft sensor could also be stopped and it was working again.
08.05.2020 19:53 # 11
antep
I had a pc connected, could not detect any malfunction, after the vehicle stopped, the oil pressure level on the screen is very low, but there is oil.
is it hard or bad
08.05.2020 19:53 # 12
If the oil pressure level is too low, it may be in the sensor. in the oil pump.
08.05.2020 19:53 # 13
antep
Hello again, I took my car to the special service, there was a malfunction of the solenoid valve, he said, it was due to this, because the engine did not protect the smoke from the exhaust emission, the engine was protecting itself, but after my stop stopped, the oil pressure level was low and it has something to do with it.
08.05.2020 19:53 # 14
akk0212
the oil lamp is on when i accidentally hit it on departure, i think it is normal
08.05.2020 19:53 # 15
KILIC
The brothers are electronic as a result, there is a possibility that if the electrovan has failed, it is likely to be from it. Did you delete the error? First, see if you will repeat the same error.
