My vehicle stops at the first start?
08.05.2020 14:51 # 1
seyhanak
mrb friends I've been following the forum for a long time just by reading it, but now I have a problem!
My car is 2006 model 206 petrol / lpg li. If the vehicle has been parked for a long time, the vehicle starts when I start to start, but the speed drops below 1 and stops within 1-2 seconds.
The same thing happens in the 2nd march but there is no stopping event in the 3rd march.
I'm sure there is gas in the tank!
I wonder what's wrong?
08.05.2020 14:51 # 2
muhlisoz
Did you have the vehicle idle?
08.05.2020 14:51 # 3
a situation close to this happened to me .. my situation was about lpg. There was no abnormality when the vehicle was on the gas, it would take a hit if you hit it 100 times. but after wearing lpg, it started not getting the first game2. In the third round, however, I would go to the LPG service, no matter how many times I had it installed, I couldn't renew the spark plug, get double nail plugs and shake it, lpg ci finally went to another LPG, he found the problem, when I stopped the car, the room was missing a little LPG due to a problem caused by the brain. The engine was drowning .. After installing a new brain, the problem has been greatly improved .. Let's see what will be yours.?
08.05.2020 14:51 # 4
hasimayaz
It is necessary to measure the pressure of the gas pump. It may be difficult to press the empty hose when the petrol is drawn into the tank.
08.05.2020 14:51 # 5
seyhanak
Friends, something interesting happened today, there is no problem when I run the car without the clutch depressing the gear, neither the speed falls nor the stop! Even though I dont give gas at a time, it is going to stop when I run it in gear and the clutch is pressed, the gas suddenly rises and it continues to work normally!
I'm very confused friends, where could the problem be?
08.05.2020 14:51 # 6
hasimayaz
how is the vehicle's expense ?? Are there any performance problems?
08.05.2020 14:51 # 7
seyhanak
the vehicle is perfectly normal in terms of fuel and performance! why?
08.05.2020 14:51 # 8
hasimayaz
If there is no problem with the gasoline expense, it may not be from the fuel pump .. it looks like the lpg brain for now. It is useful to show a good LPG master. hasimayaz 2010-07-25 11:57:26
08.05.2020 14:51 # 9
seyhanak
Mr. Bey, thank you for your support, my LPG kit is guaranteed.
08.05.2020 14:51 # 10
serFBdar
I have the same problem, if you get results, would you share it with us. thanks.
