MY VEHICLE ROLLANT IS FALLING 3 TIMES BEEP SOUND |
| 08.05.2020 19:56 | # 1 |
WHEN THE VEHICLE IS IN THE ROLE, THE ROLE IS 7. SOME TO STOP. and SPARK YOU KNOW HAS CHANGED, CARE .We are IGNITION COIL DEĞİŞMEDİM.ÇEKİŞ in B PROBLEM NO, that ARISING FROM YOUR OWN GÖZLEMLERİM by ROLANT FALLING ESTIMATES EDİYORUM.MASLAK TA SPECIAL I ROADS to the PEJO SERVICE, ALL NORMAL VEHICLE LPG SİSTEMİBEYB the BOZUYO DİYEBİLİRİM.B I WAITING FOR HELP from A MASTER VARMIDIRİBİL the arkadslar could JOB SOLVE .TELIM: 05532526015 REGARDS. ABDULLAH
| 08.05.2020 19:56 | # 2 |
sonerkyl |
According to the rules of the forum, let's not use capital letters. As for the problem, the throttle was cleaned, and if it was cleaned, adaptation was made. Have the idle valve checked. the coil may be malfunctioning.
| 08.05.2020 19:56 | # 3 |
mrb, I cleaned the throttle.It has just changed.Adaption has not been done.If you want to make the adaptation lpg ci, the room injections measure so come. now, teşekkkürler ..
| 08.05.2020 19:56 | # 4 |
sonerkyl |
If there are problems with gasoline injectors, the vehicle will either sing or work hard. The setting of lpg injectors is done by looking at the settings of the gasoline injectors. The problem that the lpg ci master needs to know is obvious when the pc is connected. Meanwhile, you can even adapt the throttle by yourself. related topic http://forum.peugeotturkey.com/forum_posts.asp?tıd=42396&title=307-bogaz-kelebegi-adaptasyonu-nasil-yapil is
| 08.05.2020 19:56 | # 5 |
mrb link does not work. thanks |
| 08.05.2020 19:56 | # 6 |
sonerkyl |
[QUOTE = helpless] mrb link does not work. Thanks copy and paste directly opens the subject hojam.
| 08.05.2020 19:56 | # 7 |
ONE OF THE GASOLINE INJECTOR IS ABOUT TO FINISH. REPLACE IT WILL BE CORRECTED. I HAVE THE SAME PROBLEM
| 08.05.2020 19:56 | # 8 |
Everything to straighten after cleaning the gas future
