my vehicle pulls to the left
08.05.2020 15:16 # 1
ask307
Hi friends;
My car pulls to the left with every departure. I made a new front balance adjustment or something, but the problem continues.
08.05.2020 15:16 # 2
Are the tires different from each other? beside the pattern ...
08.05.2020 15:16 # 3
Serhun
If the body is very likely to be as it says, if the tire air is equal, then disassemble and try again will help you make progress towards solving the problem. Good luck with.
08.05.2020 15:16 # 4
metin
I think that if the left tire holds better than right, it will pull towards itself.
text 2011-04-14 09:05:20
08.05.2020 15:16 # 5
ask307
tires, I bought 8 months of zero, I traveled 7000 km in total, goodyear efficiengrip tie rod balance when I had the front and back ones in the front, master tire weather can be effective
08.05.2020 15:16 # 6
Serhun
Air pressure will have an effect, it must first change right and left, and if the pull direction changes, there may be a possibility that one of the brakes will be tight if the tire does not change.
08.05.2020 15:16 # 7
metin
It can also be from the air, if it is lower than the other, if the edges of the tire are more swollen, just hold it by the middle of the tire, naturally it can not stick completely, so it can.
08.05.2020 15:16 # 8
goktug
good year is one of the worst tire brands. the master said. If the pull is not much, use old ...
08.05.2020 15:16 # 9
goktug
that is, even if the tire is bad, you can also adjust the tie rod balance. I think the probability of being from the air is poor, if the pull is too much ...
08.05.2020 15:16 # 10
mdincer34
Let me explain the incident that happened to me, I bought a quality tire before that, I said zero in my car anyway, I escaped cheaply, but the tire I bought was 8 times balanced, they did not find a solution to the problem of shaking, they did not look like I thought I would have a bill or take it or I will give you to the court and they returned the tires. .Simple of my vehicle 307, I made the front set last rot balance, the vehicle was pulling to the right. for now
