my vehicle passed out :( emergency aid !!!!
08.05.2020 16:51 # 1
Mfirat
When I first encountered the malfunction, when I passed over a small water loop of 50-60, the indicator lights turned off, the radio turned off and asked for a tape code. cukura dustugum ı do the same thing
indicator lights go on radio turns off and stop the car when i put the starter on (on) again the indicators hit the end (full speed of 170 170 rev 6500) touch the wheel as soon as it touches the steering wheel. electrical problem but where: S
thanks
Mfirat 2012-06-08 23:10:02
08.05.2020 16:51 # 2
Mfirat
don't you have a thought? & nbsp;
08.05.2020 16:51 # 3
senol73
There may be a lack of contact in the chassis cable of your vehicle. Look at the strength of the cable connected to the battery and whether it is loose. Check at the place connected to the body. div> If one of your electric cables touches the body of the vehicle, it can also do so. Usually, the electrical tape used in the cable joints may also make a short circuit from the cable to the vehicle body due to the stripping of the cable due to the heat.
08.05.2020 16:51 # 4
badcombatant
It is useful to open the part where the vehicle has the bonnet and a separate fuse box, if any, and check for water or moisture as soon as possible.
08.05.2020 16:51 # 5
Mfirat
So when I connect it to the computer, is it okay?
08.05.2020 16:51 # 6
yigiteroglu
Check the wiring of battery terminals and tighten wd40 to battery terminals.
08.05.2020 16:51 # 7
Mfirat
Eyw .. I'm in the industry now, I cleaned the battery terminals, I changed the disc pad when it was not on the account, no problem for now but let's see what to do next
08.05.2020 16:51 # 8
toga406
oxidation or short circuit due to water, I will probably pass as it dries
08.05.2020 16:51 # 9
tellotello
[QUOTE = Mfirat] Eyw .. I am in the industry, I have cleaned the battery terminals now, I have changed the disc pad when it is not on the account, but now there is no problem but let's see what to do in the future [/ QUOTE]
Get past & nbsp; < img src = "smileys / smiley1.gif" border = "0" alt = "Smile" title = "Smile" />
by the way Have you changed? Is it possible to provide information & nbsp; "Big
08.05.2020 16:51 # 10
Mfirat
Valeo brand disc pad including 195 pounds of labor
