My vehicle is very slipping
08.05.2020 17:15 # 1
cnrars
my friends tires are new, I bought lassa and may manufacture, winter tire of course 15 inches, I have 15 steel rims on it, but my vehicle is slipping on wet ground and light misty weather, I have trouble getting the car on turns, even though I do not press the brake and go slowly.
In addition, the left front wheels act as if the other 3 wheels are moving independently when I move the steering wheel 1 inch, the car cannot recover itself, & nbsp;
Passing I wrote a post about the week about the humming from the front, I went to Göral, they said that the left front ball should change, and they lifted it with fiber, when I turn the wheel, I think the pad and the drum are touching each other, and the sound of the two iron rubbing together, they said the left ball but they couldn't be sure, they might be on the remote control, I'll go again this Saturday, but can the problems I wrote above have anything to do with it? Also 350 pounds (including labor) is not much for the ball?
08.05.2020 17:15 # 2
moschino
If you drop the car, it may work in turns, make the engine brake when it is too difficult to overload the brake in its non-slip :)
08.05.2020 17:15 # 3
cnrars
I do exactly the same, I keep downshifting on wet roads but this is not the solution, the vehicle is a bit in the air, how can I lower it, what should I do and how much is the average cost?
08.05.2020 17:15 # 4
gngburak
torsion balls, workmanship 350tl normal
piece price & nbsp; pair 70tl repairman takes workmanship 50tl
08.05.2020 17:15 # 5
cnrars
The authorized service that gave this price said the price of 190 pounds, a total figure of 300-350 (for the left ball), but this imbalance, sliding and humming of the vehicle is not related to this, right? Because the sound coming from the left comes from the hum, and when the master lifts the wheel, there is a sound when it turns out. what happens and how much it takes almost?
08.05.2020 17:15 # 6
206x-line
check the tire air & nbsp; even if it is more than normal
08.05.2020 17:15 # 7
cnrars
[QUOTE = 206x-line] check tire air also & nbsp; it does more than normal [/ QUOTE]
how many should normally be?
08.05.2020 17:15 # 8
serkan719
If you are from Ankara, I am a lathe.
If there is a problem in torsion, we will see it together.
08.05.2020 17:15 # 9
206x-line
mine had the last 32psi air hit but it was still hard by the way & nbsp; psi value is written on the top of the tires so it can be hit
08.05.2020 17:15 # 10
_semihk_
not from the rot setting, brother ..
08.05.2020 17:15 # 11
cnrars
[QUOTE = _semihk_] Let it be from the rot setting, bro .. I went to have high speed tremors, rot and balance adjustment was done, then this tremor passed, but this time this buzzing and sliding started, especially on wet ground
08.05.2020 17:15 # 12
_semihk_
They did not remove eyebrows while making eye.
08.05.2020 17:15 # 13
furkanyakar
If the rear brake pads are worn or do not hold properly, it may cause slippage due to the fact that all the load is on the front wheels ...
