MY VEHICLE IS RISKING THROUGH PIT
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 308 (After 2014)
08.05.2020 20:41 # 1
cerdemguzel
Hello everyone Handshake About 2 weeks ago I bought my first car (2nd hand 308 bluehdi automatic) and joined the peugeot family. I had never used or boarded a peugeot vehicle before.
When I turn light steering with my vehicle, the back side of the vehicle seems to be swept as any hole goes over the bump etc. I feel it especially on the left. This skidding is not as severe as a skidding / slipping enough for the ESP to be engaged, but it feels very uncomfortable, instant loss of control and breaks my confidence in the vehicle. It reduces driving comfort.
I have never used a peugeot citroen vehicle before. I was using Opel astra hb. The difference in suspension will of course be, but this is not a vehicle-specific feature, it is quite annoying. I also researched this vehicle and bought it. In the tests carried out, this is a vehicle that has good grip and cornering ability. What do you think this problem is caused by? Is there anyone else with this problem among you?
08.05.2020 20:41 # 2
yigit_dark
My vehicle is 206. As I mentioned, when I enter a road that is broken in the pits, the wheels are cut as if the undercarriage stays there. I am very surprised at this situation. The undercarriage has no new sound in my car. I think this is a chronic problem that I have never seen in other vehicles. The steering wheel empties officially scares me.
08.05.2020 20:41 # 3
samet206
First of all, the comfort of the ride is important, but it does not disturb the vehicle line in such cases rather than the feeling it should be. If there is a situation such as not collecting itself on the road, it would be troublesome. 206 is a vehicle that can make you feel especially knocking, but it is a vehicle that makes itself felt by feeling it in the least way even in critical situations.
08.05.2020 20:41 # 4
ggitaristt
If there is a feeling of slipping on the back, but it does not slide, you should have the torsion bushes checked.
If the tires are bad and / or have wide sidewalls, it gives a little slipping feeling.
08.05.2020 20:41 # 5
cerdemguzel
[QUOTE = samet206] First of all, the comfort of the ride is important, but it does not disturb the vehicle line in such cases rather than the feeling it gives. If there is a situation such as not collecting itself on the road, it would be troublesome. Since it is high, 206 may give a special sense of skidding, but it is a vehicle that gathers itself by making it feel the least in critical situations, even in critical situations.
[/ QUOTE
The feeling of skidding is momentary. Something 1-2 seconds is as if the vehicle is stern and collects immediately and does not spoil itself. I am not a person who spends my way of using speed and enters bends fast. I'm a city calm user. Already this skidding happens when passing through any hole at low speeds.
08.05.2020 20:41 # 6
cerdemguzel
[QUOTE = ggitaristt] If there is a feeling of slipping on the back, but it does not slide, you should have the torsion bushes checked.
There is a feeling of slipping but the vehicle is not slipping as you say. My tires are 205/55/16 goodyear brand. The braking distance is pretty bad, I think to change it anyway.
08.05.2020 20:41 # 7
ggitaristt
[QUOTE = cerdemguzel]
The tire sizes are all okay.
08.05.2020 20:41 # 8
cerdemguzel
[QUOTE = ggitaristt] [QUOTE = cerdemguzel]
I'll take it to the service tomorrow and have it checked
08.05.2020 20:41 # 9
First of all, welcome to us. As our ggitarist fellow said, there are problems with the back torsion bushes, I think six sets etc. Show the wheels, I guess they will have an impact on the grip.
08.05.2020 20:41 # 10
uzunca961
Soner and I have 308 too. I drive the vehicle for about 30k km, but I have never encountered such a skid. I use Goodyear efficientgrip performance, if it is the same tire, it is one of the best road tires you can encounter, and the story is the rest. For that reason, I do not think that it is rubber, unless it is pumped. If the warranty of the vehicle continues, tell the person who takes it to the nearest service and take a test drive.
08.05.2020 20:41 # 11
pusutr
It felt like a shock absorber problem. 308's handling is very good.
08.05.2020 20:41 # 12
cerdemguzel
I went to the service 2 days ago. The master at the service made a test drive with my vehicle, he said, I couldn't see the problem. We went to the test with their test vehicle, this time I drove. I felt it was much less skidded and better attached to the road than my vehicle. Meanwhile, their test vehicle had winter tires.
My vehicle was under warranty. Front rear suspension group, I got the mechanical parts checked. It was said that there is no negative situation. They said that because of the torsion, this style could make a feeling of sliding, but it would not be a skid that the vehicle would recover in a very short time, it was entirely due to the characteristic feature of the vehicle.
Tomorrow I will have Pirelli snow control 3 winter tires on my vehicle. Let's see if this will reduce the feeling.
08.05.2020 20:41 # 13
pusutr
[QUOTE = cerdemguzel] I went to the service 2 days ago. The master at the service made a test drive with my vehicle, he said, I couldn't see the problem. We went to the test with their test vehicle, this time I drove. I felt it was much less skidded and better attached to the road than my vehicle. Meanwhile, their test vehicle had winter tires.
If your tires are not zucchini, I think they have deflected their heads. Most of them are characteristic of service.
08.05.2020 20:41 # 14
ggitaristt
Sister cold weather and especially rain snow frost vs summer tire will not work in that weight car .. So your car maybe really slips one by one ..
The torsioned car holds the road well, it does not lie flat. Torsion only reduces comfort.
I rode the falcon for 15 years, I did not need any snow tires, I always saw my job.
08.05.2020 20:41 # 15
Avangarde
My vehicle is 2016 308 hdi. More than 19,000 km. I have that same problem. When you hit a roadside guard, the back of the vehicle seems to be blown away. When I first bought it, I noticed it instantly. Honestly this is disappointing for me. I don't think it's related to the tire or something. Hopefully it is not characteristic of the vehicle. But as far as I can see, we don't have this problem. It looks like he's gotten rid of you in the service. I haven't been to the service yet. Let's see how it will be solved. Because it's a dangerous situation. Imagine hurling at high speeds.
08.05.2020 20:41 # 16
let's do a research on foreign forum sites. This is the first time I heard this problem, as you said in the new 308s.
08.05.2020 20:41 # 17
KILIC
Sir, the tires in the rear may have very high air. As a simple matter, in my opinion, check the air of a rear tire.
08.05.2020 20:41 # 18
GokhaN
I think your problem is completely rubber
08.05.2020 20:41 # 19
Macrostr
I live the same situation in octavia. If I turn to the corner on the rough road or if there are pits and bumps, the rear wheels seem to be cut off from the ground. The same feeling does not happen when there are passengers in the back. My guess is that it's about weight. New generation vehicles are too light to be economical. I think a load of 100 kilos in the trunk or fill the back seat with a friend and I think. Tires may also be too bulging. The reference values for the 308 17 rims are 32-34 PSI, but I usually keep it between 30-32. It increases comfort and absorbs the impact a little better. I have not seen any harm.
08.05.2020 20:41 # 20
lazpeugeot
definitely the rear shock absorbers are exhausted. probably cat in wedges. unfortunately, our lion's shock absorbers are not a quality shock absorber. also expensive
Page : / 2
