My vehicle is protected when it runs on gasoline.
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » Other Models
10.11.2020 23:43 # 1
aALYy
Hello.As I mentioned in the title, when I start my Citroen C3 2017 1.6 vti on gasoline, after 10 seconds the engine lights up and the car starts to stall and the fan turns on. Since the single cylinder stops, the traction of the car does not exceed 90 unless I force it. I went to 3 services. Malfunction Cylinder 1 appears (in detail it was something like burning issue etc.). Since the vehicle is a new model, there are no parts to be tried. Spark plugs were changed again the same. They say it can be bobbin, we can not try. I do not want to give 1,500 TL to the experiment. It stutters again when it goes into the tube while working while working on the gasoline. But there is an interesting situation like this. There is no problem when I run the vehicle directly in the tube.
11.11.2020 00:20 # 2
omerb
Greetings, what exactly the fault code gives. Also, are the ignition coils in your vehicle one by one or in groups of 4? Bnm 207 vti also one by one. Then you can check if the fault is still in bank1 by swapping the coils. Apart from that, a clear fault code is required for comment. Do not run the vehicle directly in lpg. Cold lpg does even more harm. It can happen if you have to, right after the vehicle warms up.
11.11.2020 01:09 # 3
aALYy
In the fault finding, "Cylinder 1" was written. Coil malasef is one of 4.
11.11.2020 08:36 # 4
omerb
The full fault code is required in the form P ...... It is easier to help
Peugeot Forums - Peugeot Fan Club © 2025
FromOwner.co.uk — Buy & Sell Directly from Owners in the UK. No dealers. No commissions. Just from owners.
