my vehicle is not working
08.05.2020 16:04 # 1
GTI_MEMO
My vehicle's reversing lamps did not light up. My electrician friend noticed that the socket going to the rear lights from the side of the engine was plugged into the wrong socket, and he connected it to the other empty socket right next to it, and the lamps burned. There is a role of gasoline in the ignition, there is a cable in front of the dual brain, we also changed them in front of the fan, there is a cable attached to it with a single screw located on the opposite side of the fan.
08.05.2020 16:04 # 2
Our members who have completed their new membership and entered the forum, please introduce yourself by opening a new topic under the heading "Let's Know Our Members ". Filling in all the information will help us to get to know you better.
1.- Your name and surname:
2.- Your age:
3.- Your vehicle (Brand, model):
4.- Your hobbies:
5.- Your profession:
6.- Where did you hear the site:
7.- Your Blood Group:
8.- Your horoscope:
9.- The team you support:
10.- Which county or province are you in:
11.- Your MSN address:
Thank you for your attention.
Peugeot Turkey Fun Club Management
Www.peugeotturkey.co & www.peugeotturkiye.co I
08.05.2020 16:04 # 3
GTI_MEMO
where will i write
08.05.2020 16:04 # 4
Look at the top, let's get to know our members under the heading. You're new topic open, you will answer those questions and Göz Kırpma
08.05.2020 16:04 # 5
mon
Didn't you restore the socket you replaced for the reversing lights?
Gasoline is too much in a non-working engine, and raw gas is thrown from the exhaust ... thoughts like nonsense.
I believe that you will get more detailed answers if you write the model of the vehicle in the signature section.
Have a nice holiday.
08.05.2020 16:04 # 6
GTI_MEMO
When we run out of gas in the vehicle, we do not take the starter or it works like that.
08.05.2020 16:04 # 7
mon
Is there any burning in the fuses? Do not burn a fuse related to the ignition system.
08.05.2020 16:04 # 8
GTI_MEMO
No master they always have firing firing time
08.05.2020 16:04 # 9
berk2309
If everything is broken with the crazycm socket, the electric system and fuel system of this vehicle have been tampered with. quick help
08.05.2020 16:04 # 10
GTI_MEMO
everything is okay just the problem is that if too much gasoline is coming in normal consistency it can cause this problem okay well my vehicle 97 model 1.6 gasoline tube no immobile
08.05.2020 16:04 # 11
taksicicocuk
Could the timing belt be broken if the engine is not running faster than normal?
08.05.2020 16:04 # 12
GTI_MEMO
He looked at it, only the brain remained, so I say anlıcan that if I take the brain to repair, I have to connect it to the device and compare it with a solid brain.
08.05.2020 16:04 # 13
berk2309
If they say the injection brain, go out to the scrap dealers, look at your brain, you will get 100 200 for the repair, you will find 300 or more, maybe cheaper. I did not understand if this brain is broken because of the socket, I was sure that it was correct before changing the socket.
08.05.2020 16:04 # 14
GTI_MEMO
I took the ztn tactic bar, measured the bar fln, plugged the spark plugs, we do not know if the same brain is broken again, but the only remedy is that I say that if I take it to the master, his memories are defective.
08.05.2020 16:04 # 15
berk2309
are you sure the spark plugs are firing?
08.05.2020 16:04 # 16
taksicicocuk
If my immo friend was an immobilizer, when I turned on the ignition, if the key appeared on the screen, I would say the brain is strong.
if your car has a socket, connect it to the computer but
if gasoline does not come on and ignites, it is either spark plug, spark plug cable or coil
08.05.2020 16:04 # 17
taksicicocuk
bend to the brain does it have a burning smell
08.05.2020 16:04 # 18
GTI_MEMO
There is no smell of burning or there is a very small thing in this car.
08.05.2020 16:04 # 19
berk2309
I would ask another master if I was in your place
08.05.2020 16:04 # 20
taksicicocuk
which industry of your memo vehicle
