My vehicle is having trouble getting into 2nd and reverse gear.
08.05.2020 16:29 # 1
Dostum
Hello ... I became a new member ... A useful forum ... My vehicle 2005 1.6 HDİ 307 SW PACK Model ... I just bought the car, showed it to the service while buying it, it was said no problem. I started to have the problem of not shifting into gear, so it passes but the vehicle (in 2nd and reverse gear) does not move, after a few times the clutch and re-engaging movement, the fatal fate passes. I used diesel and pejo for the first time. but I think it is not the problem for me to shift to 2nd and reverse gear every time. I would appreciate if there are & nbsp; Friends & nbsp; who have information and advice ...
08.05.2020 16:29 # 2
woshborn
I think the engine is doing cold & nbsp;
08.05.2020 16:29 # 3
MagicPerformance
there is no strain on other gear shifts?
08.05.2020 16:29 # 4
I think I would look at the gearbox oil ...
08.05.2020 16:29 # 5
MagicPerformance
[QUOTE = street art] I think I would look at the gear oil ... [/ QUOTE]
I need to strain all the gears, even if it is gearbox oil.
08.05.2020 16:29 # 6
When there is a problem in the transmission oil, it usually has the problem of shifting in 2nd and reverse gear. he finished ...
08.05.2020 16:29 # 7
Dostum
Sorry guys ... Answer your questions & nbsp; I couldn't ... I just came from the master who left the industry pejo service and opened his own shop ... & nbsp; ... The problem is solved ...
The master first lifted the gear bellows and the rim, dismantled the chest under the front digital air conditioner ... they tried to fix it before with a makeshift thing, but it was displaced again and although the gearbox did not reach the respective (2nd and reverse) gear of the gearbox although it was replaced in 2nd and reverse gear, the gearshift was not able to transmit the relevant gears to the gearbox due to the transmission and the engine. the car could not move ... Just like, when we try to write the spring inside the ballpoint pens we use, the escape inside the tip of the pen when we try to write & nbsp; ...
Here, let's not replace this rope completely, he said around 300-35o tl ... It was fixed nicely with iron wire and plastic clamp ... Thank goodness now it is the transition of 2 and reverse gears. I say it and it is very comfortable ...
08.05.2020 16:29 # 8
marad
your eyes are bright :)
you are so lucky to find such a master everywhere ... I have the same problem but I'm afraid to go & nbsp;
08.05.2020 16:29 # 9
qqyyxx
[QUOTE = Dude] Guys, I'm sorry ... Answer your questions & nbsp; I couldn't ... I just came from the master who left the industry pejo service and opened his own shop ... & nbsp; ... The problem is solved ...
The master first lifted the gear bellows and the rim, removed the chest under the front digital air conditioner ... they tried to fix it with a makeshift thing, but again it was dislodged and although the gearbox did not reach the respective (2nd and reverse) gear of the gearbox, it was unable to transmit the relevant gears to the gearbox because the gearbox did not reach the respective gear lever & remained idle & nbsp; the car could not move ... For example, just as we tried to write & nbsp; after taking the bow inside the ballpoint pens we use, the master said that he escaped into the tip of the pen ...
Let's not change this rope completely, he said around 300-35o tl ... fixed it with iron wire and plastic clamp ... thank goodness right now 2 and hi gears switch I say it and it passes very comfortably ... I curse people. You will buy another vehicle tomorrow. What would you think if the same thing happened to you? Anyway, I am glad that you can solve the problem without overpowering and trying.
08.05.2020 16:29 # 10
Dostum
Thanks...
08.05.2020 16:29 # 11
MagicPerformance
Get well soon, I'm glad the trouble was resolved.
08.05.2020 16:29 # 12
GiTaRRa
Not gearbox oil. There may be a problem with the gear shafts. Could you hit the ground?
08.05.2020 16:29 # 13
harmus
First of all, good luck, my friend. I got it last year & nbsp; The same (2nd and reverse gear) problem I had with my (307 SW 1.6 petrol) car. I showed it to the service as I am one of those who do not give up the original in terms of service. We changed the printing pad or something and the problem disappeared. Sometimes there is still no gear in the first move in reverse gear. Either shifting the gear lever to the left and putting it back again, or gently lifting the clutch, it engages reverse gear. They said they can do it because there is no synchromesh gear from the service. You were quite lucky in the sense of a master. He is glad that he solved his simple and skillful problem, but also his knowledge of the master.
08.05.2020 16:29 # 14
ysndrsn
I'm waiting for urgent help. Peugeot 206 2006 model automatic transmission. Everything was normal, I parked the car an hour later I came to the gear mnrp but I do not go to d I can not go forward. What is the problem, can you help me
08.05.2020 16:29 # 15
vbmaster
My teacher came to my head in a safety vehicle, I bought back 5 10 mt, went to n and then d passed (Note: my friend's gearbox exploded in Bolu mountain got stuck 1500 lira got better) :)
08.05.2020 16:29 # 16
ysndrsn
But it doesn't feel like it's going to happen to me.
