my vehicle is driving
08.05.2020 16:28 # 1
estair
"Cry" my friends tool puts gasoline raw working unevenly & nbsp; gasoline has a smell and & nbsp; cycle not exceeding 3000 bn speed can cause 100 does not delay I pressed until the end of the pad, helde fuel consumption increase what should I do "
08.05.2020 16:28 # 2
Ucyuzalti
It is normal to drip water from the exhaust when cold, but the others are not normal, this is due to the fact that it is the ignition system. I say throttle cleaning and check the air filter.
By ignition system intent:
Spark plug
Spark plug cables ... etc ignition component parts
08.05.2020 16:28 # 3
estair
how n & nbsp; When the klebek cleansing cleanse on the weekend, the original filter is installed, the vehicle stops more and more when there is open air that burns more
08.05.2020 16:28 # 4
Ucyuzalti
In the open air filter, the air is entering more as a flow rate, I know that it burns better in the air, which means that the ignition is weak I think & nbsp; "Wink"
08.05.2020 16:28 # 5
estair
Either the car is still beautiful, I still did not solve the stop event, I used an idler adjuster, did not fix it.
08.05.2020 16:28 # 6
Ucyuzalti
Your vehicle stops heating? Is there LPG in the car? Reviews
08.05.2020 16:28 # 7
semih
I have 1.6 110 hp 206, I have 5000 6000 cycles in me, but the car is gone, I do speed on the highway 140 150 says it was difficult but I did all the maintenance but I didn't clean the throttle, I think our problem may be.
08.05.2020 16:28 # 8
Ucyuzalti
1.6 8v 306 I see 200km without much difficulty, less than 180 mountains, so do not speed, of course & nbsp; "LOL"
08.05.2020 16:28 # 9
scorpions_64
I have similar problems, I opened many topics, I could not find a complete cvp. extraordinary fuel increase, not eating gas when the engine is stuck in the morning, falling from the traction and fastness of the vehicle (I press the engine is shouting but the vehicle is not going but the road is on the way). As he said in his three hundred and six friends, it may also be from the ignition system. I heard a malfunction from a few masters called burn-in, so after the valves have been worn, but it was not getting power, the solution was to open the cylinder cover and change and grind all the valves. He said he wasn't making the mix. Let me think logically and say ok he does it on gasoline, but I shouldn't do it in LPG, because I said there is an independent injector in LPG, look at your ignition, and he said.
08.05.2020 16:28 # 10
estair
If I do not want the vehicle not to go, the ordinary person who wears the gearbox did not tighten the screws and since it did not separate the self-ignition, it was clear that the name of the ordinary person would have the engine down, so few tips hold the end of the screw
08.05.2020 16:28 # 11
yavuz25
get well.
08.05.2020 16:28 # 12
06OzGuR06
What people are there, they are doing things that are of vital importance.
Get past. "Smile" Reviews
08.05.2020 16:28 # 13
yavuz25
[QUOTE = 06ÖZGÜR06] What people are doing, or even doing vital things in the form of defiance.
Get well. "Smile"
My brother have you ever heard of someone who forgot to tighten the table screws?
08.05.2020 16:28 # 14
estair
God bless your friends
if he makes a apprentice, no matter why I pulled the car to the service that was done. We roasted it to normal so there is no cutlery, according to the number of wires, the wire length does not establish itself.
08.05.2020 16:28 # 15
Ucyuzalti
If the car does not go, even if the car does not go out, the pressure pad is finished. when the ignition is weak, the car does not consume gas because better ignition is needed in cold weather to burn gasoline, the better ignition in perfonmasta, the better fuel performance performance
08.05.2020 16:28 # 16
Ucyuzalti
Get well man
08.05.2020 16:28 # 17
djchaos
[QUOTE = estair] If I do not want the vehicle not to go, the ordinary person who wore the transmission did not tighten his screws well, and he did not remove the separation, so he kept the tip of very few screws on the road
< / div>
God bless the past
08.05.2020 16:28 # 18
Griffe
Hello ...
I think this problem is with me .. if the car is loaded and I touch the gas pedal a bit, the smell of gasoline wraps inside the car. We had it checked once and they said that there was no problem in its gasket .. I had the butterfly cleaning done about 3-5 months ago .. I changed the spark plugs a few months ago ..
