My vehicle ends at idling :( My result is husran ....
08.05.2020 17:27 # 1
volkan22
good forums my car peugeot 306 2.0 auto: & nbsp; Today, my car suddenly slowed down on the road in the D position, my car was almost close to stop, then I gave gas in the position of N, it seemed as if there was water in the gas, it went up unevenly after hours, the performance exhaust bursts and comes in the smell of gasoline when it runs normally at high rpm when it comes to 1000 rpm, As long as I do not pull my feet out of gas, everything is going on the road, I pull my feet out of gas, exhaust explodes, patir stops. & nbsp; It improves sometime again, the same malfunction occurs again, I would appreciate it if you help me ... volkan22 2013-03-26 17:27:06
08.05.2020 17:27 # 2
The explosion of the exhaust means that the fuel that has not been burned is going to the exhaust manifold. So in some way the burning in your vehicle is not correct. That is why you experience a stop. First you need to have the spark plugs checked. If the problem does not arise, I think it is necessary to overlook the ignition system.
08.05.2020 17:27 # 3
volkan22
Today, I connected it to the computer, it did not cause any malfunction, I will replace the spark plugs, maybe it will be corrected, maybe I will be happy if the ones who come to the bole help you.
08.05.2020 17:27 # 4
rockwaryumm
[QUOTE = volkan22] I connected it to the computer today, it did not cause any malfunction, I will replace the spark plugs, maybe it will be corrected, maybe bole beyes will be happy if you help me.
08.05.2020 17:27 # 5
my volcano is past ..
[QUOTE = rockwaryumm] [QUOTE = volkan22] I have connected it to the computer today, it did not cause any malfunction. QUOTE]
Does the vehicle have LPG?
No LPG use on the island "Wink"
08.05.2020 17:27 # 6
rockwaryumm
I didn't see where you are, sorry. Because the auto honda accordda had made of gas in one, the air intake made from it. Bida throat butterfly cleared and improved when the idling sensor changed. That's what I know
08.05.2020 17:27 # 7
ismailkaya
I do it like stop and again he is working at idle, he is doing the break in the evening.
08.05.2020 17:27 # 8
volkan22
My brother, I went to the mechanic, he was getting air from somewhere, he said, the engine malfunction light burns, sometimes connect it to the computer, said it, we did not show it, it is best to fix it occasionally.
08.05.2020 17:27 # 9
volkan22
unfortunately today i get the car to the mechanic said it is getting some air from somewhere ...
the spark plugs didn't change the problem ....
then the master inserted the air hoses of the vehicle one by one ...
inserted the air sensor etc. sockets of the butterfly while it was in operation ...
I said, do not insert a master, I said them, brain zeroes, I said I heard it from somewhere, I did not manage, unfortunately ...
vee my vehicle STARTED AT ATM ... :(
the spark plugs that we had inserted were not karati and it was fine & nbsp;
The spark plugs we just installed were black in 5 minutes ... I think it was in ... ACAIB CNM SKILDI ...
then the most correct thing was to connect it to the computer and then it broke my car, it got worse ... & nbsp; k At least I was going, the car was now hard to move even from his seat.
08.05.2020 17:27 # 10
emre_akdag
Thank you, my friend, I wish you went to a repair shop, I think it would be a recommendation or something .. I wish you were in Bursa. we would help :(
08.05.2020 17:27 # 11
volkan22
Idling is broken, I think the sensors are gone, the black smoke is throwing up. Now the cost of the tractor etc. is 150 TL, only the road cost will go & nbsp; let's see. Let me reset the brain in my peugeot service ...
08.05.2020 17:27 # 12
Insert the battery terminal and wait for a while and follow the starter with it. You may not need to pull it.
08.05.2020 17:27 # 13
volkan22
spark plugs were inserted, they were clean, it was not even blackened, new spark plugs were installed, the problem did not go away. >
It did not work for 5 minutes. We said we should put the old spark plugs back in. The new spark plugs were black ...
My
old spark plugs were like ice. .. what happened after the tactic again & nbsp; the vehicle was no longer running
is dancing and dancing in the way of D, while stopping the vehicle ...
< div>
tomorrow, we set off with the morning shooter ins will not write a big expense, i will write the result here again thanks so much ...
< br>
08.05.2020 17:27 # 14
EErgul
get past volcano what is the last situation? you naap
08.05.2020 17:27 # 15
mynet84
I have a 2005 model peoget 307 1,4 auto. There was no problem in my vehicle when it was in gasoline, but when the vehicle was slowing down or stopped when it was in the gas, it gave gas to itself or stopped. There is no master that I did not show, every master I took asked me to change a piece of it, I went to the expense but it did not improve. The last time I took it to a master, he said, let's change the spark plugs, the problem said, we changed the spark plugs, this time the problems that did not come out on the gas started to appear on the gas, the vehicle stopped even when it was on the gas, even more increased this problem, the vehicle ramps on the ramp, falls from the traction to the stopping point. Anyway, I went to another master, the room said, which spark plugs did not happen to this vehicle, he said. Anyway okay, whatever is appropriate, I said, let's put it on, I changed the spark plug, but the problem did not improve again. Whatever you did, I couldn't handle this problem. Do you have any advice for me? (repairs I did on the vehicle; throttle cleaned, oxygen sensor changed, spark plugs changed, gas pump changed, air filter changed)
08.05.2020 17:27 # 16
ismailkaya
mynet84 happened to the car after cleaning the throttle :)
08.05.2020 17:27 # 17
ARAL
the same problem is in me now I am waiting for your reply
08.05.2020 17:27 # 18
NBY18_GTI
Have the oxygen sensors checked, brother, I was in the same trouble, everybody said something, the part that I did not change was left. Finally we realized that it was from the oxygen sensor. Now click it;)
08.05.2020 17:27 # 19
volkan22
My vehicle has been replaced by an oxygen sensor.
08.05.2020 17:27 # 20
ErolSs
I have the same problem, little is not so much & nbsp;
intake manifold pressure breaker
oxygen probe with green socket
When I connect to the computer, these will be released at the first opportunity.
