My vehicle eats excess fuel :(
08.05.2020 16:26 # 1
volkan22
hi friends & nbsp;
my car peugeot 306 & nbsp; 2.0 l & nbsp; 16 v & nbsp; automatic transmission & nbsp; bl4 gear box.
I don't have exhaust performance muffler on my vehicle & nbsp; and I put the catalyst straight straight pipe is coming back performance exhaust war so much
Do you notice that too extreme?
I make about 30 km with 7 liters of gasoline, I do not know how to cry in the city. Thank you from now.
08.05.2020 16:26 # 2
Ucyuzalti
With 9 liters, I make 100 km from the city & nbsp; If it is really technical value of your vehicle, I guess let's look at the user manual for 13 lt 100 km.
08.05.2020 16:26 # 3
volkan22
my car 306 automatic transmission & nbsp; 1998cc 16v bl4 transmission & nbsp; including everything in the original air filter only exhaust performance & nbsp; I can not give meaning & nbsp; I do not press it too much. it comes up and down slightly but very lightly: S
08.05.2020 16:26 # 4
Ucyuzalti
Now I have looked at your vehicle's manual, it has 12 lt of fuel, it is like 13, you say that it does not remove fuel from the idle sensor, it may be the smell of exhaust, it may be at the first start, but normally it will not come, the possible problem I know is in the ignition system elements, this spark plug cable, spark plugs have your ignition overtime the better the ignition, the better the performance in the engine, the less fuel. Clean the idle valve and throttle for another irregular operation, see if the air filter is dirty or not, see the pipe assembly that allows the air to get out from the outside, if there are any broken, etc. If there is broken, the engine runs hot in cold weather, that is, by taking the temperature of the engine, the engine runs inefficiently in hot weather. this also increases the amount of fuel, in short, well-maintained car less burns and how are the main maintenance?
08.05.2020 16:26 # 5
volkan22
I gave the vehicle to the full service, everything changed new, but this fuel makes me crazy. Also, as you say, my car's power is very strong, as you say, maybe the ignition disorder war fuel is not burning. a href = "http://www.facebook.com/l.php?u=http%3A%2F%2Fimg263.imageshack.us%2Fi%2Ffotoraf0258.jpg%2F&h=sAQE7NuHa" target = "_ blank" rel = "nofollow"> http://img263.imageshack.us/i/fotoraf0258.jpg/
08.05.2020 16:26 # 6
Ucyuzalti
Car ciks have & nbsp; "Smile" Orr in gasoline prices How brother I How many liters of gasoline going liters some 30 pounds with this my same thought in Turkey I think our speech would be more accurate. Burning of fuel is generally related to ignition, don't worry too much, your car regrets later & nbsp; "Wink"
08.05.2020 16:26 # 7
volkan22
Whoever I ask, they call me exhaust, the car is running smoothly, they get air from somewhere, they change my car from time belts to spark plugs & nbsp; and I want to tell you the incident happened ..
goturdum man manually pressed, we do not understand the veteran we do not understand, we think it will be done
after all, i started dr. >
then the air-conditioning compressor switches on and off. I said to the master, why did my master say so? Why did he do it like this?? >
I don't see, come on, look, the fans are freezing like crazy!
I'm going to insert the bumper, I'll see it, bring it to me Monday. & nbsp; a supe has entered into me, a supe has entered the vehicle. / div>
while driving on the road, my car started to operate like a tractor top cover!
I immediately stopped my call, I called my mechanic, believe it & nbsp; & nbsp; We drained the gas from the air conditioner & nbsp; said the master said cheap you saved good and stopped it or else the machine would hit him said he'd be afraid of him.
After eating, I will not tell me, I do not know what is broken, it needs spark plug, machine does not want acma or something.
08.05.2020 16:26 # 8
volkan22
gasoline prices & nbsp; liter 3 tl brother want 20 tl to 6.5 lt or something & nbsp; there is not much difference S: & nbsp; i already make 30 km to 6.5 liter: S
08.05.2020 16:26 # 9
Ucyuzalti
I understand that there is a master driving tractor there "LOL" we have brothers who understand better than me on this site, we will help you if you share your problems with them & nbsp; "Wink" it is not very difficult to remove the exhaust. It is absolutely certain that it will throw out non-original exhaust fuel, you have chosen the most burning machine in the aga 2.0 16v bidet automatic & nbsp; "LOL" to him actually a good lpg goes on but i don't know if you can overcome its trouble & nbsp; "LOL"
08.05.2020 16:26 # 10
volkan22
walla brother do you believe it is not afraid of gasoline, i'm hungry, i'm afraid to ride it a lot. i'm throwing the gas, would you believe & nbsp; I'm throwing 60 TL gasoline 2 hours pert don't ask, but the pleasure is priceless :)
08.05.2020 16:26 # 11
Ucyuzalti
6.5 km to 30 km? ney ney & nbsp; "LOL" naptın sister, you are close to 100 km to 22 liters of gasoline. I have a prop, not a gas tank hole "Smile"
08.05.2020 16:26 # 12
Ucyuzalti
If your vehicle is 13 liters, it will cost 39 lira when we multiply the normal by 3 & nbsp; ie 100 km You have to go Member in Turkey you 40 pounds petrol 4280 following the "LOL" Bite & nbsp; You are here aboo
08.05.2020 16:26 # 13
volkan22
I do not understand too little, I do not have a gas tank from my vehicle. Do you know what this means?
so I can get 1 TL from where you look in km vehicle :(
08.05.2020 16:26 # 14
volkan22
bro, I will shoot you a video, I will throw it to you, you will understand & nbsp; :) sound nissan 350z let me swallow power pattern gas or you can not believe it, I can not put the exhaust, it gives me a wonderful pleasure.
08.05.2020 16:26 # 15
Ucyuzalti
There are 20 liters of fuel for 60 pounds. & Nbsp; "C & nbsp; I don't end up with 20 liters in my car so in a city tour, or rather a normal vehicle. />
08.05.2020 16:26 # 16
Ucyuzalti
Even if the sibling exhaust is not complete, the car will not burn so much. border = "0" alt = "LOL" title = "LOL" />
08.05.2020 16:26 # 17
volkan22
I make an average of 60 km with 13 liters of gasoline, but if you ask me if you ask me if you ask me if you ask me, halfway, I'm going to pull the air very fast. shake in fire fever I can not explain the eruption of bursts & nbsp; let's take care of the exhaust.
08.05.2020 16:26 # 18
volkan22
I'm throwing the octane of & nbsp; 97, you will see the video, I will go to 6.5 liter 30km with walla oath & nbsp; 60 km to 13 lt but something in the city!
08.05.2020 16:26 # 19
volkan22
I have another car war diesel ford dating I throw it 7 liters I make 80 km I make 90km walla
I usually use it
08.05.2020 16:26 # 20
Ucyuzalti
We have friends who do the same work here, so I never heard of refueling like catalyst cancellation, both when the catalyst keeps toxic gases out of fuel, so & nbsp; "Wink" there is another thing in your car brother and pretty hard thing & nbsp;
Page : / 2
