my vehicle dropped from traction emergency aid 307 sw 110 hp |
| 08.05.2020 19:54 | # 1 |
| 08.05.2020 19:54 | # 2 |
I do not know how long your holiday was, but I have read the possibility of a reduction in the flammability of fuel in many places. Could there be a problem in the vehicle? Fuel etc. Can you give me information?
| 08.05.2020 19:54 | # 3 |
Are you sure the problem is not in the turbo? I think it would be better if you take it to another master, if it doesn't pull on the ramps, the problem is likely to be in the turbo. If there was another problem, he would not have gas or speed on the straight road.
| 08.05.2020 19:54 | # 4 |
take care of turbo and injectors
| 08.05.2020 19:54 | # 5 |
KILIC |
the turbocharger hose may be torn or dislocated.
| 08.05.2020 19:54 | # 6 |
ALLEX |
[QUOTE = SWORD] turbocharger hose may be torn or disconnected. [/ QUOTE] this is the highest probability. Also check your air filter.Once my vacuum cleaner returned to the bag, the traction dropped. When the road construction zone stabilized or used for a long time on dirt roads, replace the air filter at the earliest opportunity. get your fuel from the brand you always know do not have any unnecessary load on the vehicle unless you have to |
| 08.05.2020 19:54 | # 7 |
absolutely turbo. After connecting the computer and measuring the turbo pressure, it is not understood whether there is a problem with the turbo. I had the same problem in my car, I wrote to the forum yesterday.
| 08.05.2020 19:54 | # 8 |
Yes, first of all, thank you very much for your interest. I traveled about 4200 km. On the ramp, even the Hyundai i10 passed me on the ramp, he mastered the turbo with his small engine. the cycle is 4 thousand but the vehicle seems to swell. He is not going to shout somehow. I did not go to the service, intermediate fuel always total excelium air filter has changed new diesel filter 2 times maybe because it is the same but still another idea ???
| 08.05.2020 19:54 | # 9 |
Before this incident, engine oil leaks from the bottom of the injectors of the vehicle.
| 08.05.2020 19:54 | # 10 |
ALLEX |
[QUOTE = fkul] yes guys first of all thank you very much for your attention I traveled about 4200 km on the ramp, even the Hyundai i10 passed me on the ramp with this small engine, the master measured the turbo, my pressure is normal, my car might be 105 thousand maybe, but it is going 180 190 straight but when you change the gears, you can immediately press the gas. it was being pushed forward, now when you press the gas, it is 4 thousand, but the vehicle seems to swell. He is not going to shout somehow. I did not go to the service, intermediate fuel always total excelium air filter has changed new diesel filter 2 times maybe because it is the same but still another idea ??? [/ QUOTE] My teacher looks like a clutch. If the speed is increasing but the traction does not start immediately, there may be only two reasons. As soon as the engine turns over or knocks, either the clutch is missing or the vehicle wants a snap ring. If you say there is no movement, there is no other option. I hope it's over and I hope your problem will be fixed as soon as possible. |
