My vehicle doesn't eat gas
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » Partner tepee
09.07.2020 14:58 # 1
Bg48000
My 2012 Peugeot Partner Tepee 90's vehicle does not eat gas and its speed starts to decrease when the ramp hits the road while driving. This failure does not always do bi does not do bi does not. I could not understand, I am a person who carries out their daily maintenance, but I could not solve the problem. I showed it to the master, he said we need to change the turbo or we should change the brain, I didn't want to believe it. Can friends with knowledge on this subject help? The vehicle is at 110 thousand km. Note: I'm going to get crazy, help me now.
10.07.2020 15:26 # 2
Berkay Erdinc
Measure the pressure of the fuel pump first. If the fuel does not come with sufficient pressure, you can do it.
13.07.2020 23:10 # 3
Bg48000
He doesn't always do that, if I start on the gas, but if I accelerate slowly, it's okay.
16.07.2020 09:03 # 4
Hello teacher, the problem of this is usually related to cracks in the turbine hoses, the seals in the gaskets - turbo electrovalves - vacuum hoses - airdebimeters.
16.07.2020 14:58 # 5
Bg48000
I am sure that there is no problem if the vehicle is turbocharged, neither is blowing nor the smoke is emitting smoke.
15.08.2020 04:06 # 6
Efsanepartnerr
Hello, I have the same problem with my 2013 model partner. I haven't had the opportunity to show it yet. Did you solve the problem? Can you share what it is caused by
18.08.2020 21:37 # 7
Bg48000
It continues in my vehicle again, but it is not the same as before, when I had it checked, I disassembled the air flow meter and cleaned it well with the lining spray. And I also had the cooling fans checked in my vehicle, I fixed the malfunctions in them, now it does not cause any problems, but I believe it will be completely solved when I change the traction air flow flow meter.
19.08.2020 08:09 # 8
If the problem is largely corrected after cleaning, as you said, the flow meter is like a problem, sir.
19.08.2020 20:23 # 9
Bg48000
When I found a flow meter, I could not find it in Kars, unfortunately, I will look at it in Izmir and I will appreciate it if I find it, at least I will be comfortable.
19.08.2020 20:41 # 10
burhanakbass
hhh
19.08.2020 20:42 # 11
burhanakbass
Hello friends, if you have paugeot 508 semi-automatic ETG 6 to buy, first watch the video below, they talked about the pros and cons for a long time. C5 citroen, Passat, jetta, astra, insignia, corolla, focus, superb, octavia would better watch it. he really told everything. https://www.youtube.com/watch?v=o_05yFOAHaM&list=UUAGSkmiPSu3T7oz_agx-mTA&index=2
26.08.2020 03:37 # 12
Efsanepartnerr
Hello brother, have you found a meter in the air and I wonder if the problem is solved.
