My Vehicle Doesn't Work !!!
08.05.2020 18:29 # 1
OttomansCihad
Hello, everybody, have a nice day, friends, I found a problem in my vehicle and I would like to consult you for advice and information from you. The problem was when I went to work yesterday morning, that I went to work a day before, there was no problem, but I got into the car yesterday morning, I turned the ignition but the car did not work, just the sound I heard every time I turn the contact is the same, just TIK nothing else. What do you think is the reason for this and how much does it cost? Thanks to everyone in advance ...
08.05.2020 18:29 # 2
yawruaslan
There is a margin engine or a commander problem, get into the industry as soon as possible before you get more trouble.
08.05.2020 18:29 # 3
rolandgarros
The starter may have run out of charcoal, the lamps are on, or the tape is running, if the battery is not finished, the problem is probably the starter. Is it possible that the fuel is out? Have you also tried to deliver gas without idling in the vehicle?
08.05.2020 18:29 # 4
OttomansCihad
Everything is normal, there is no problem in the fuel, there is no problem in the battery, everything is normal, just click the crazy sound that I say, there is no other problem, I think. So how much does it cost?
08.05.2020 18:29 # 5
emrepunar
the starter's maintenance time has come and an average of 100-150 interest has passed
08.05.2020 18:29 # 6
OttomansCihad
Thank you very much, I would like to ask one more thing for the information you provided. What a maintenance this starter wants, my vehicle 2007 206 hdi
08.05.2020 18:29 # 7
rolandgarros
I guess it's not something that changes very often. I think it also directly affects the end life of coal related to how many contacts you make.
08.05.2020 18:29 # 8
emrepunar
Depending on the situation, but the amount of 150 will be done, of course, the workmanship of the place is important in this kind of work.
08.05.2020 18:29 # 9
OttomansCihad
Okay, thank you very much for the information you provided.
08.05.2020 18:29 # 10
ahmed206
Do not continue to hold the starter after the vehicle starts, this way you burn the engine very easily. Take a look at your working habits, you probably get it wrong somewhere.
08.05.2020 18:29 # 11
OttomansCihad
Thank you, but I don't think I will hold it down again after starting the car. The car is a bit neglected, I am the second owner, I was using a lady before me, maybe I think the reason is very high :))
08.05.2020 18:29 # 12
ahmet_bjk
probably the starter motor has run out of coal, the same thing happened to me. I do not remember the price, but I know that there is no 100-150 lira. It can be around 50 lira.
Also, it is not related to misuse. These coals have a certain lifetime.
Also, if you lock your vehicle from the control and open it with the key, make sure that you do not start the vehicle in the same way.
ahmet_bjk 2014-04-27 19:42:19
08.05.2020 18:29 # 13
tolga.onal
The polar heads of the battery may have been loose. It happened to me yesterday. I was cleaning the battery terminals in the same way. .. Check if you want
