My vehicle doesn't eat gas
08.05.2020 19:55 # 1
Mert Nacar
Hello friends, my 307 1.6 hdi 110 hp vehicle has not started to eat gas at high speeds for the last 1-2 months. When I want to accelerate from the 90's, I root the gas, it doesn't eat for 15-20 seconds, and then it starts to eat, and something sounds like humming whistling sound by the engine. Can anyone help if they know the solution
08.05.2020 19:55 # 2
firstly welcome. If it sounds whistling, it seems to be related to the turbo. I recommend you to connect and check the pc.
08.05.2020 19:55 # 3
Mert Nacar
Thank you for your advice. So what might be the problem of late gas eating at high speeds?
08.05.2020 19:55 # 4
You're welcome. There may be several reasons for getting late gas. injectors-egr-air flow meter- fuel pump - diesel filter - throttle - air and turbo hoses etc. will need to check.
08.05.2020 19:55 # 5
Mert Nacar
I understood thank you. Well now my vehicle is the 2006 model. If I take the car to the original service, I connect it to the PC and find out what the problem is.
08.05.2020 19:55 # 6
unfortunately they charge a fee depends on the room service. If you have your vehicle serviced, they do not want a fault detection fee. approximately will charge a fee of around 100 TL.
08.05.2020 19:55 # 7
Mert Nacar
Where did I get into this car, ask everywhere :) thank you for your help :)
08.05.2020 19:55 # 8
Well, my job is a bit of luck in diesel vehicles, especially the use of fuel oil change period is important. It is not known how the previous owner used it. For 10 years old, I think it is good to find a good master.
08.05.2020 19:55 # 9
rzy.dnz
If you take the throttle first when you go to normal, then get the reaction in the night, then the vehicle has been contracted first and started to press the gas if it was eating gas at the same time.
08.05.2020 19:55 # 10
lamazibici06
I say look at the filters or something my friend
