My vehicle does not work help 206 hdi
08.05.2020 20:05 # 1
chakra
Hello friends, I left the house today, my car worked as usual, and I went 700 m, stopped at the cash machine to withdraw money and got back, the car worked normally, went 20 meters, stopped. it didn't work when i tried to run it again. I tried to run a couple of times, tried it, stopped again after a minute and did not start, pressing the straps normal oil water ok battery is in good condition.
I scanned from the phone and got the following codes
p0337
P0402
p1351
P0102
what do you think the problem is from?
vehicle 2005 model 206 1,4hdi
chakra 2016-12-16 21:40:59
08.05.2020 20:05 # 2
celaleddinemre
the first error is not working due to p0337, the teacher may not be firing because of the crankshaft sensor.
2nd and 3rd code egr valve and sensor
4. code is mass air pressure sensor
if you have them checked too, the vehicle will regain its former performance
celaleddinemr to 2016-12-16 22:13:53
08.05.2020 20:05 # 3
celaleddinemre
https://otomobilteknoloji.blogspot.com.tr/2016/03/motor-krank-devir-sensoru-nedir-ne-ise-yarar-arizasi.html
this is the blog page that i found to fix the malfunction teacher
08.05.2020 20:05 # 4
chakra
Thanks, my teacher said on the phone the master said, but I couldn't get there in the dark at night, I would go to the car in the morning and look at it first two days ago.
08.05.2020 20:05 # 5
celaleddinemre
Thank you, teacher. May it be a good past to come to the property. it is probably out.
08.05.2020 20:05 # 6
gergerli
Let me know, I was curious about the phone, I scanned it on the phone, you said that you gave these codes or do you have an obd device connected to your vehicle?
08.05.2020 20:05 # 7
chakra
Exactly, my teacher has an OBD Bluetooth device.
08.05.2020 20:05 # 8
x571
[QUOTE = chakra] exactly, my teacher has an obd bluetooth device. In such cases, it was easy to read the error codes and call the master [/ QUOTE]
How much is the brand model, how much TL?
08.05.2020 20:05 # 9
you know that device can read your vehicles, you can find it if you search for my teacher name obd 2 elm 327. They sell the infantry between 20-30 TL. aliexpresten is around $ 3.5-4 but i have information about old type obd protocol vehicles that you have reading problems. I recommend you to prefer wired and wireless. You can only view the win7 32 bit operating system with a computer. Software CD is sent with the device. Aliexpreste price is around $ 6. If you want, you can take it with a wireless device and try it. If it doesn't read, you will need to buy a wired device.
china site link
https://tr.aliexpress.com/item/s-cak-sat-obd-v2-1-mini-elm327-obd2-bluetooth-otomatik-taray-c-obdıı-2-araba/32672080531.html?spm= not 2114.010208.8.18.ızw
GittiGidiyor
http://urun.gittigidiyor.com/otomobil-motor-aksesuar/elm-327-obd2-super-mini-bluetoothlu-v2-1-araba-arac-ariza-tespit-cihazi-250894927
08.05.2020 20:05 # 10
chakra
and those with bluethoots only work on android phones
Apple has models with wifi for around $ 11 aliexpresste
08.05.2020 20:05 # 11
KILIC
I love this opel, you can read the fault code with the brake and accelerator pedal.
08.05.2020 20:05 # 12
Selox
Brother first you have to replace the crankshaft sensor. But you should be original, you should definitely pay attention to this. Tücrübeyl to. In the first place, it does not get stuck on malfunctions with an Egr valve. Remove the air flow meter and clean and re-install the deposits with the lining spray.
08.05.2020 20:05 # 13
chakra
thanks unfortunately the problem was caused by the crankshaft sensor supplier industry with the original
I changed the problem, now the only problem in my car is that when I load it on the gas, the black smoke throws the master, if you want, come empty time, let's empty the solid, he said.
08.05.2020 20:05 # 14
Selox
[QUOTE = chakra] thank you unfortunately the problem was with the original crankshaft sensor original
Just like I said. Get well soon. It is likely that it can solve carbon clean. 70 TL or something.
08.05.2020 20:05 # 15
ersin61
I ordered this product in the evening 3.49 $ 12 odd TL free shipping is available.
08.05.2020 20:05 # 16
chakra
I use that device too I hope it will come soon. Nowadays, cargoes in China seem to arrive late.
the https://play.google.com/store/apps/details?id=org.prowl.torque&hl=
I recommend using this application. When you type obd on google play, many applications will be available. You can find and download the pro version of this application from the internet.
08.05.2020 20:05 # 17
ersin61
Thank you, there is no shortage of time :))
08.05.2020 20:05 # 18
ersin61
Also, the pro version in the link you provided my friend is paid, so does the free version fully open all the functions ..
08.05.2020 20:05 # 19
ersin61
I have not ordered at home, I will try tomorrow. By the way, I arrived early. I had placed an order on December 19, almost 15 days.
08.05.2020 20:05 # 20
celaleddinemre
If you search for torque pro on the internet, you can find a site that has published the full version of the program. If you put it on your phone with an intermediate cable, you can get the application without paying the fee. then enter the application and start the vehicle or connect the device ready to start, open the application from the phone and it will be connected
